Sponsored by: Real Truck
Still loose steering
Old Feb 23, 2018 | 07:41 AM
9905's Avatar
9905
Sorry, I have searched and searched, but I have not found what to do next.
My F350 has about 150,000 miles on it, and the steering wheel has about one inch of travel in each direction before the wheels begin to turn.
I did a steering gear box on my excursion and it was night and day difference.
So I did try to save some money (Redhead on the excursion) because I am not sure how much longer I am keeping this truck. I went to Oreilly's and bought a rebuilt steering gearbox.
What a wonderful time installing because of some phantom sized power steering line bolts. After the install, my steering was just as bad if not worse.
Checked and found the "tie rod" from the pitman gear arm to be shot. I replace all four. No improvement. I checked the track arm and there is no movement there.
I am stumped, can it be the "new" steering box was just as bad as the original?
Thank you in advance for any advice that can be given.
9905
Old Feb 23, 2018 | 08:59 AM
Chuck's First Ford's Avatar
Chuck's First Ford
have someone rocking steering wheel back and forth
and you look under truck... check for movement..
also check the steering shaft going to steering box...
if no movement....its the steering box.
Old Feb 23, 2018 | 12:45 PM
Lawnpro979's Avatar
Lawnpro979
Correct me if wrong, but isn’t there an adjustment on the steering box?
Old Feb 23, 2018 | 12:51 PM
jetjockey99's Avatar
jetjockey99
Yes there is an adjustment, but you need to be very careful in adjusting it to avoid creating other problems. What brand did you get from O'Rielly's? The only aftermarket reman I've had any luck with, other than Redhead, and they have had their issues too, is the Cardone brand, not that they can't have a bad one as well, but they have been consistently better than any other I've seen.
Old Feb 23, 2018 | 01:12 PM
Chuck's First Ford
as stated..
but unless you KNOW HOW.. return it.. if you think but box is bad or out of adjustment.
Rachel Moody
15
Jan 16, 2017 11:51 AM
Matt In Detroit
1978 - 1996 Big Bronco
25
Feb 19, 2011 07:51 AM
CooGAR
Oct 14, 2010 10:42 AM
13MWZ
Nov 24, 2007 05:38 PM
toysrfords
Jun 16, 2005 07:22 PM
