Sponsored by: Real Truck
2016 F350
Old Aug 31, 2020 | 11:50 AM
Talbot1966's Avatar
Talbot1966
2016 F350
On the weekend my 2016 F350 was driving normally then the traction control light came on the door chime alert was dinging and dash was turning on and off and flashing speedometer would go from zero to travelling speed hill dissent check engine traction control etc. were all flashing Truck was jerking even when I was able to pull off and Truck was in gear but stopped it
Old Aug 31, 2020 | 11:57 AM
Just Strokin's Avatar
Just Strokin
A tad more info would be nice.
Is this a gas or diesel truck?
4x4?
Any DTC's (codes)?
Did it re-start and drive ok?
Old Aug 31, 2020 | 11:59 AM
seville009's Avatar
seville009
https://www.ford-trucks.com/forums/1...l-problem.html
Old Aug 31, 2020 | 12:03 PM
Talbot1966's Avatar
Talbot1966
2016 F350
6.7 diesel
4x4 lariat
250,000 Km’s
no codes
restarted and has been fine since
Old Aug 31, 2020 | 12:04 PM
Talbot1966's Avatar
Talbot1966
2016 f350
It was jerking even when stopped but in gear
Old Sep 1, 2020 | 08:45 AM
saratoga2011's Avatar
saratoga2011
Most likely the giant electrical connector attached to the parking brake bracket way up under the driver's side footwell. Many have had the same issue, myself included.
Disconnect and re-connect the plug, cut the tie holding it to the parking brake bracket and tie it to the dashboard crossmember. Never worry about it again.
6.7zenick
Jun 25, 2020 03:27 PM
2016 F-350 daully
6.7L Power Stroke Diesel
Mar 26, 2020 03:54 AM
broncoman604
Aug 21, 2009 08:03 AM
Darren Forcier
Aug 7, 2007 08:49 PM
