Sponsored by: Innova
amps/help
Old Oct 20, 2003 | 09:29 PM
IDontThinkSo's Avatar
IDontThinkSo
amps/help
ok i need some help, what does 4 channel amp mean .and how about 2 ohm what is the difference from a 2 ohm 4 or 8
Old Oct 20, 2003 | 10:07 PM
silvapain's Avatar
silvapain
A four channel amp can amplify four distinct channels (LF, RF, LR, RR). Ohms are a measurement of resistance. The lower the number, the better. If you run two two-ohms speakers in series, the result is a four ohm resistance on the line. If you run two four-ohm speakers in parallel, the result is a two ohm resistance on the line. The trick is to match the resistance of the speaker configuration with the handling of the amps. Too high ohms, and the amp will push too hard and overheat. Too little ohms, and you will underpower the speakers and blow them up.
Old Nov 8, 2003 | 09:38 PM
furrby's Avatar
furrby
you got that wrong. if the ohms go the low then the amp will over heat and cut off. too high and there will be a lot less power to the speakers. just helping.
furrby
Old Nov 8, 2003 | 09:54 PM
silvapain's Avatar
silvapain
Your'e right. Thanks for the correction.
78'fordtruckguy
Jan 30, 2009 12:05 AM
V10man
Nov 9, 2007 11:11 AM
awf-150
May 18, 2004 09:51 AM
bill6302
Dec 21, 2003 11:19 AM
Munkey
Nov 29, 2001 04:23 PM
