Sponsored by: Innova
ohm question
Old Nov 8, 2007 | 01:17 AM
V10man's Avatar
V10man
ohm question
Any issues using 2ohm speakers with a 4ohm amp? Thanks.
Old Nov 8, 2007 | 06:24 AM
riggz's Avatar
riggz
That depends on what you mean by 2ohm speakers. Are they dual voice coils? How many speakers? You do not want to put a 2ohm load on an amp only rated to handle 4ohm.
Old Nov 8, 2007 | 10:40 AM
V10man's Avatar
V10man
They are Infinity 6 1/2" componets 6020cs. Kenwood 40W x 4 amp.
Old Nov 8, 2007 | 01:42 PM
fordboy_52's Avatar
fordboy_52
you can wire 2 speakers to make them 4 ohms. then it works great
Matt
Old Nov 9, 2007 | 01:49 AM
V10man's Avatar
V10man
Well they sound great. What will be the issue? Burnt up amp?
Old Nov 9, 2007 | 08:29 AM
furball69's Avatar
furball69
Lower impedence speakers will cause more current to flow through the amp, more heat, possibly blown fuses, possibly blown power IC's.
Hot power IC's put out more distortion so at higher volumes it won't sound as good. May or may not be an issue for you....
Old Nov 9, 2007 | 11:11 AM
fordboy_52's Avatar
fordboy_52
they might sound even better when wiref correctly. it will also be easier on the amp. there is a tutorial in the audio video tech folder, clikc back once and at the top of the page. it will help you wire your speakers for your amp. then you might be able to turn the amp down and let it breath easier
Matt
cjgray1974
Apr 10, 2014 06:28 PM
The Ride
Jan 17, 2014 12:36 PM
Jager
Nov 24, 2010 03:41 PM
jbfourt3
Sep 15, 2004 09:36 PM
bill6302
Dec 21, 2003 11:19 AM
