On our 2000 EX do I need to count the splines? And is it possible while it's on the truck? Is the 32 spline for 2wd only or did they use 32 and 36 on 4wd.
I'm planning on buying this one LARES 11602Info Consider a Steering & Suspension Repair Manual when replacing critical Steering or Suspension components.
$334.79
A thread in the tech folder looked like they might use both boxes. I was hoping one of you knows for sure.
You can barely see the splines on the top of the arm. There are 4 larger gaps, there are 9 teeth between the large gaps so it should be a 36 spline unit. We bought a new Lares for my daughter's 87 Silverado and it's working great so I'm getting another new one for our EX.
