Replace and Upgrade power steering - Ford Truck Enthusiasts Forums
Old 01-17-2018, 07:26 PM
cabe cabe is offline
cabe is starting off with a positive reputation.
Lightbulb Replace and Upgrade power steering
Hi I'm looking to replace AND upgrade my steering set up. The unit I have right now wonders like it's on some sort Australian walk about.
Has anyone got any pointers or ideas on upgrade kits. I like to make sure its done right and as modern as possible but keeping it as stock as possible at the same time?
Old 01-17-2018, 10:29 PM
jakeharp's Avatar
jakeharp jakeharp is offline
jakeharp is starting off with a positive reputation.
Com'on man ...
Remember the Com'on man commercials, they were great.... Hey what year model, motor, configuration is your truck ? and what current style of steering does it have, if ya know...
Old 01-17-2018, 11:19 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Welcome to FTE, we are good, but we need just a little more info. If its that bad of a wanderer I'd bet the steering box worn out. Red Head or Blue top time, or maybe just replace the rag joint or the steering shaft with a Borgeson...
All depends on your application, things like 2wd, 4wd, Y or T linkage set up, power or manual steering, Garrison, Bendix, power assist.... Maybe ck in to upgrading to a Saginaw p/s pump too?
74 F100 (with low mileage) is all your profile has...
Blue-Top Steering Gears, Inc.
https://www.redheadsteeringgears.com/
Old 01-17-2018, 11:38 PM
It's 1974 Short Bed F100 2WD Automatic.
I do know its aC6 transmutation
The motor is a big block but haven't ID it yet (it not the original)
Old 01-18-2018, 01:15 AM
jakeharp's Avatar
FE
Looks 2 be an FE360/390 to me... 2wd with the dip stick forward, front sump ..original intake manifold. Measuring the stroke will tell the tale.. .. safe to say the gear box and shaft prolly needs some lovin, those links Rich posted are great places 2 use... Unfortunately the steering components arent cheap to rebuild.. Just did my whole system, was pricey, but steers like a new truck Same valve covers i have...
Old 01-18-2018, 08:38 AM
77&79F250's Avatar
Used OEM parts guy
here is a Saginaw upgrade link. https://wt4x4.com/tech/saginawswap.htm
Old 01-18-2018, 06:08 PM
72rtchallenger 72rtchallenger is offline
72rtchallenger is starting off with a positive reputation.
If its the steering box I assume you have a lot of play in steering even when not moving ? Its the usual culprit and readhead an bluetop are pricey and I read a lot of reviews and seems more recently there quality control went down hill some the past few years , so I bought one from napa and has lifetime warranty and easier to take back if a problem occurs and much cheaper , havent tested yet as still rebuilding the truck , also check the radius arm bushings and check the drag link and other components in front end before replacing the steering box
Old 01-18-2018, 09:40 PM
ranger140892 ranger140892 is offline
ranger140892 is starting off with a positive reputation.
Old 01-18-2018, 11:10 PM
@72rtchallenger, I think its the box the steering has almost 20% play when not moving.
All great information, thanks. It would be helpful for me (I'm new) and maybe other who read thread to create a "Shopping List" of components (may be not brand specific) that a full steering rebuild would need.
Old 01-19-2018, 09:58 AM
Cabe, if it's the gearbox there are two options I know of. One is to buy a parts store rebuilt gearbox. But keep in mind that if that gearbox had play in it when rebuilder received it, it'll still have that play when it ships out. All they do is replace seals and bearings.
The other option is Red Top. They machine the shafts true, then fit oversized bearings. I have two of these boxes, and my friend just put one in his Scout. All are 100%. No slop whatsoever.
Once your gearbox is taken care of you'll probably find that there are still some things you'll need to do in order to get rid of that slight dead spot at the top. Bushings, ball joints and tie rod ends may need replacing also.
Old 01-19-2018, 11:08 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Those are cool valve covers.
Old 01-19-2018, 11:27 AM
@ranger140892 thanks, I looked at the Napa part. A recon units is a good price but but a new unit is up there with all that others +Ted Top give you a core trade in rebate of $200.
tx @mark.a, I need to clean up the whole engine bay, and get a shine on the valve covers ;-). The previous owners have add a lot of crap, there seem to be three sets of horns and two alarm systems, and some sort of trailer powered brake kits - none that work.
Anyone got suggestions on the pump set up?
So far on the shopping list for a (F-100, 1974, 2WD, FE390 w/C6 trans):
Old 01-19-2018, 01:54 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The other option is Red Head. They machine the shafts true, then fit oversized bearings. I have two of these boxes, and my friend just put one in his Scout.
Ford/Saginaw integral P/S (introduced mid-year 1969 on 2WD's) has a flaw, there are no bearings on the sector shaft, it rides on the bare housing.
Before too long, fluid begins leaking from the sector shaft seal.
Red Head takes the housing, machines it and installs the needle bearings that Ford omitted, so they could sell a gazillion sector shaft seal kits!
So called auto parts store 'rebuilt' gearboxes are nothing more than resealed gearboxes.
Old 01-19-2018, 02:03 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
These are cooler!
Old 01-19-2018, 05:48 PM
flowney's Avatar
flowney flowney is offline
flowney is gaining momentum as a positive member of FTE.
Quote:
Borgeson has a nice upgrade to Saginaw for FE engines.
Firewall Steering Column Brace pchelp 1967 - 1972 F-100 & Larger F-Series Trucks 13 10-23-2017 11:32 AM
upgrading original fabtech performace coilover Colby Matranga 2004 - 2008 F150 0 10-02-2017 12:56 PM
Suspension and steering upgrades! the_auto_tech 2009 - 2014 F150 50 08-24-2017 03:20 PM
Steering Wheel Upgrade or Repair 651_F350_KR 6.0L Power Stroke Diesel 11 09-23-2016 10:54 AM
Interior upgrade from 06' to 2014 Obiii2316 1999 to 2016 Super Duty 0 08-08-2016 06:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
