Sometimes no start.
Old Aug 25, 2020 | 03:38 PM
ohioplatt's Avatar
ohioplatt
Sometimes no start.
I have a 94 F250. 8 month old battery with clean terminals. Some times my truck will not start. No nothing. Nothing works. I' ve then jumped it and everything works fine. The only thing out of the ordinary is voltmeter reads between 10 to maybe 12 volts. Checking my battery Voltmeter reads 13.6 to 14.5 depending on rpm. Good current flow also. Ideas?
Old Aug 25, 2020 | 04:27 PM
EllieMae94's Avatar
EllieMae94
Hard to say but I had that same problem with mine a few years ago. I ended up replacing both the negative and positive cables and haven’t had the no start issue since. Check the connections at the block and the starter if you haven’t already.
Old Aug 25, 2020 | 04:42 PM
seville009's Avatar
seville009
The 10 to 12 volt numbers are low; most likely the battery is bad.
Stick a spare battery in if you have one to test it.
If the 8 month old battery is under warranty, take it back to get it tested and maybe get a new one
Vinford
Oct 19, 2019 12:43 PM
93flareside351w
Apr 28, 2016 06:53 AM
Eaglescout94
Feb 20, 2015 09:15 PM
sammatt1
Mar 24, 2014 01:00 AM
prohopwer
Nov 21, 2006 08:19 PM
