Alternator question
Old Aug 23, 2020 | 02:10 PM
SwampRattFord's Avatar
SwampRattFord
Alternator question
I've got a 4 wire alternator on my '66 352. It's chrome so it ain't stock I know. Is the 4 wire the stock the OEM wiring?
I want to replace the chrome pulley on it. Has a new belt that's a month or so old. It's tight tight and aligned properly. It squeals and want to replace the chrome pulley with a steel black or whatever equivalent.
Worse case if I have to replace the alternator a 4 wire if OEM should drop in I assume?
Thanks in advance.
Old Aug 24, 2020 | 05:11 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Stock alternator is 4 wire, yes. I think you are on the right track, chrome is slippy. Many aftermarket alternators nowadays come with no pulley and need to use yours so if yo go that route, make sure it comes with a pulley.
Old Aug 24, 2020 | 05:47 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Is it a Powermaster brand alternator? One problem with the FE engine where the alternator is mounted high on the passenger side is there is very little room and most non stock replacements will hit the head. The Powermaster puts out a steady 50-60 amps at idle and fits just like the original. Unfortunately, they only sale it in a chrome finish which ups the $ unnecessarily. I have seen a post here where you can by a bracket system that puts the alternator low on the passenger side - this removes the issue of head clearance.
Old Aug 25, 2020 | 12:52 AM
Christmas's Avatar
Christmas
A lower mount bracket allows for more choices.
https://www.ebay.com/itm/FORD-FE-ALT...cAAOSw0e9Uwd61
FordTruckfan89
Apr 8, 2015 08:12 AM
2500ak
Jul 3, 2013 07:51 AM
monkei
1978 - 1996 Big Bronco
13
Feb 26, 2004 03:40 PM
maximumhorsepower
Jan 4, 2004 07:56 PM
Torque1st
Dec 21, 2001 11:55 AM
