Body Wobble?
Old Aug 21, 2020 | 09:25 AM
Nate Bratcher's Avatar
Nate Bratcher
Body Wobble?
Good Morning Everyone,
So, I've got the engine FINALLY dialed in and took my '62 that was converted to a 4x4 sometime in it's life on it's maiden drive yesterday, and this thing seems to shake from side to side. It's bizarre, because, admittedly the shocks need to be replaced, but the tires and wheels are all looking good, and there isn't a lot of play in the body when it's parked. But when I drive it down the block, it shimmies BAD!
I am hoping there is an simple problem I am overlooking - everything is tight and looks good, so I am not sure why it is wobbly...
Any ideas?
Thanks in advance!
Nate
Old Aug 21, 2020 | 12:20 PM
robertrpeak's Avatar
robertrpeak
Warped wheel, tire with broken belt, etc..
Old Aug 21, 2020 | 03:48 PM
john jamieson's Avatar
john jamieson
Bent drive shaft. Bad U-joint. Front alignment. I would put it up on blocks/stands and run the truck so I could observe the drive train in motion
Old Aug 21, 2020 | 06:33 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Bent axle shaft, bent hub, unbalanced tires, plus everything mentioned above. I agree with putting all four wheels in the air and put in in 4 wheel drive, see what doesn't look cool. Please use good jack stands or a hoist.
Old Aug 21, 2020 | 07:19 PM
Nate Bratcher
Thanks for feedback - it makes sense that those items would definitely cause it, and I’m not sure any of this was maintained in the vehicle before I got it, so I’ll follow this advice!
thanks again!
Old Aug 21, 2020 | 10:25 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
“Body Wobble?“
Wait till you get my age.
Old Aug 21, 2020 | 11:18 PM
yardbird's Avatar
yardbird
Wobble at all speeds from take off, or at certain speeds? If the truck has sat a long time, could be the tires are flat spotted. I've seen bent rims, loose lug nuts, tires with tread separation, ect...
Old Aug 23, 2020 | 03:31 PM
Thunderkiss1965
well? Fix it?
Old Aug 25, 2020 | 08:49 AM
Nate Bratcher
Yeah - I think after looking at this list, I've decided to whittle it down one at a time... it's now at the transmission shop (the C6 is leaking and being a pain), and I'm having them check out the driveshaft and differential. While it's there, I definitely don't trust the wheels (I found 5 lug nuts missing from the 4 wheels), so I am going to find some new wheels and tires...process of elimination.... wish me luck! I'll definitely post when I discover what the underlying problem is.
jimmystoys
Paint & Bodywork
24
Jan 6, 2020 09:53 PM
Dean06919
Nov 29, 2017 10:57 AM
joe f350
S. California Chapter
Feb 3, 2010 04:38 PM
