351 trans
Old Aug 20, 2020 | 07:38 PM
Curbside1's Avatar
Curbside1
351 trans
ok so my truck i just scored is a 70 f100 was told its a 302...
Hahah..its actually a 351 with small cam and race holly 4412 carb....she flexes the truck.so.hard...but here's my issue...it still has the t170 srod 4 speed trans...cant handle this setup
Please Point.me.in the right direction for a trans that can handle the motor...will also need info on drive shaft and rear-end..im assumimg.it can't handle it either
Old Aug 20, 2020 | 07:42 PM
85e150's Avatar
85e150
Rear axle should be a 9", it will be ok but the ratio might not be what you want.
As to the transmission, a C6 would work, An AOD, a 4r70W....
Or a toploader 4 speed if you can find one, a T56 or other similar "newish" 5 speed.
Budget, manual or auto, OD or direct. Narrowing it down will help.
Old Aug 20, 2020 | 08:35 PM
Curbside1's Avatar
Curbside1
budget manual preferred
Old Aug 20, 2020 | 11:12 PM
85e150's Avatar
85e150
If you are going to go cheap, go with a C6. They will take a lot more than the old manuals, and be easier on the rear axle. Get some traction bars to keep the axle from wrapping up. That will break things quickly--u-joints for one.
Old Aug 21, 2020 | 11:47 AM
351Cleveland C4's Avatar
351Cleveland C4
AOD if you want to drive it long distance.
If you really want a manual, NP435 is nice. Or maybe a M5OD-R2.
The rear axle is a 9 inch. Well up to the task.
Old Aug 21, 2020 | 12:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Hahah..its actually a 351 with small cam and race holly 4412 carb....she flexes the truck.so.hard...but here's my issue...it still has the t170 RUG SR-OD 4 speed trans ...cant handle this setup
RUG SR-OD introduced in 1978 F100/150 with 300/302, used thru 1983.
1965/72 F100/250 2WD would have the optional Warner T-18 4 speed without overdrive. Reverse is up-towards the dash.
No truck came with a 351M until 1977, no truck came with a 351W until 1981. 1970/74 351C was not installed in trucks.
Old Aug 21, 2020 | 08:19 PM
v84960's Avatar
v84960
No truck came with a 351w until '81? I could have sworn they were in trucks through most of the 70's.
Old Aug 21, 2020 | 10:24 PM
351Cleveland C4
No 351 of any kind in a truck until '77. And that was only the 351M. But of course, that doesn't mean guys didn't swap them in.
Old Aug 22, 2020 | 01:26 AM
v84960's Avatar
v84960
I guess you're right-everything I've looked at thinking you were wrong has proven you are in fact correct. I guess I've seen enough swapped in windsors to assume they were factory.
Old Aug 22, 2020 | 02:57 AM
NumberDummy
No truck came with a 351W until '81? I could have sworn they were in trucks through most of the 70's.
351W introduced in 1969 Ford/Merc Passenger Cars, in Econolines in 1975, in F150/350 & Bronco in 1981.
351M: 1975/79 Ford/Merc Passenger Cars; 1977/79 F100/350; 1978/82 Bronco; 1980/82 F150/350 & Econoline.
Largest available engine in 1980/83 F100: 302.
Old Aug 22, 2020 | 07:10 AM
Scndsin's Avatar
Scndsin
If it is a Windsor 351 & not a 335 series engine it will have this diagonal casting at the base of the distributor.
If the casting is at a right angle, it's a 302.
You can feel it with your hand if you can't see it.
Old Aug 22, 2020 | 11:36 AM
351Cleveland C4
We don't gloat, but we know a thing or two around these parts.....
People's biggest problem seems to be taking offense to facts that aren't on their side. But facts are facts and don't care about feelings. Haha
Old Aug 22, 2020 | 12:11 PM
DirtyFerd's Avatar
DirtyFerd
I would go with a ZF. They're behind plenty of 351s. They have an OD and a granny gear. You'll have to switch to a hydraulic clutch which means mounting the reservoir and engineering linkage to the clutch pedal
big_ford_rednek
Apr 28, 2009 04:05 PM
jaceqq
16
Mar 4, 2008 04:14 PM
juchertf100
18
Jan 26, 2007 05:49 PM
david73796
Mar 1, 2000 07:56 PM
