NP435 shifting strange
Old Aug 18, 2020 | 07:01 PM
quinton144's Avatar
quinton144
So I had my NP435 rebuilt about 6 months ago by a trusted trans shop. Recently 3rd gear has been shifting a little hard and if I don’t put it into the gear slot just right it will grind. It has a new flywheel, clutch, new fluid in The trans and the clutch is properly adjusted. Any ideas what could be happening? Is that just the nature of the 435 or is something wrong?
Old Aug 18, 2020 | 08:59 PM
440 sixpack's Avatar
440 sixpack
welcome to my world. my NP435 shifted good and was in good condition but since it was out I took it to a good shop and had them put a Novak rebuild kit in it. just cause. I didn't like the fact the syncro's were made in india but I couldn't find anything better so I went with it.
Now it shifts like crap and does basically what you're saying. it's hard to get in 2nd and it grinds in 3rd.
I think it's the junk syncro's but I don't know. my shop says keep driving it will get better I don't see any improvement so I think I'm going to swap it out for the one in my shop truck I never use.
Old Aug 18, 2020 | 11:05 PM
bluovl's Avatar
bluovl
My 80 F350 had the NP435. It was tough as nails. I had a problem once with it not shifting smoothly with lots of grinding. Long story short, it turned to be the release fork mount. It was worn out. I replaced the fork and the mount no more grinding. I can't remember if I had to pull the tranny to make the repair.
Old Aug 18, 2020 | 11:21 PM
ford390gashog's Avatar
ford390gashog
The fluid plays a big part in the shifting and the syncros working. What fluid did the shop use?
Old Aug 18, 2020 | 11:49 PM
440 sixpack
Might be worth a try but don't get you hopes up. but I've tried several variations of 80-90 , I have 50W in it now and see no difference at all.
I think it comes back to the parts we have available today. hopefully someone can prove me wrong I don't want it to be hopeless.
Old Aug 19, 2020 | 10:06 AM
ford390gashog
50w Trans oil (Not to be confused with engine oil) is good and so is a MTL like Redline MT90 which provides correct friction for the syncros. Look for a fluid that has API MT-1 cert. The easy to get ones are Delvac 1300 50w, Redline MT-90 or Lucas 50w Trans oil.
Old Aug 19, 2020 | 10:13 AM
mark a.'s Avatar
mark a.
Third gear will grind if you go too far to the right of it's gate. If it has new synchronizers, then I would guess whoever rebuilt it didn't get it shimmed right.
Old Aug 19, 2020 | 12:49 PM
440 sixpack
The Redline was my first try because that's what I run in all my transmissions. then 80-90. then synthetic 80-90 and noe Valvoline 50W because that's what Novak said to try. really no difference in any of them.
Not sure how things were set up I just know the guy who rebuilt it is a well respected gear box guy. not that it isn't screwed up but I don't know anyone who's better.
Old Aug 19, 2020 | 02:58 PM
ford390gashog
How does it feel when you float the gears?
Old Aug 19, 2020 | 03:21 PM
440 sixpack
It's just 3rd gear really, but 2nd is often hard to engage from a stop. 4th is fine.
You really can't float because you don't feel anything except resistance, and then it either goes in or grinds. double clutching does no good either.
Sometimes I wonder if part of it isn't in the tower. it was rebuilt too, it just has a real notchy feel to it. the best way to explain it is as if as soon as the stop ring gets any pressure it locks in place and if the teeth aren't aligned it won't let them move to line up.
Old Aug 20, 2020 | 04:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NP435 has nylon inserts on the 1-2 & 3-4 shift forks. These crack apart/disintegrate, the pieces can fall down into the gears, jamming them up.
1-2 inserts are different than 3-4 inserts. These are obsolete, but there are 100's available NOS and are also available from auto parts stores.
d3ryl
Jun 22, 2020 10:58 PM
hondamxr
May 27, 2013 09:16 AM
AklavikCRN35
1978 - 1996 Big Bronco
Oct 4, 2011 09:57 AM
RhinoScores
1983 - 2012 Ranger & B-Series
Nov 30, 2006 10:10 PM
scurbiedog
Jan 2, 2006 04:21 PM
