Is there a cheaper alternative to the Rotunda test kit?
It's time to check the anti corrosion strength, and I have owned this truck since new, so no other coolant has been added to contaminate the mixture.
The Accustrip Rotunda kit after shipping is around $85, then more money if I need the revitalizer. At this point, might be better cost wise to drain the radiator and refill.
Is there a budget minded strip I can use to test just what I need? It's a 2015 Powerstroke woth 73K miles.
You can add the Rejuvinator twice during the life of the coolant.
I've gotten lazy or cheap. I just add the rejuvinator at your mileage and flush at 100,000
Ok, so i did a test back at 45K miles, and not even sure i did it rigjt back then, and it indicated i needed to rejuvenate, so i did.
If i just add it again now, and it doesn't need it, am i harming anything? Is there such a thing as too much?
I just did a flush at 60K miles and kept driving. I tested once and decided I would just do that. Now with the coolant changes I will switch coolants at 100K.
