Coolant test cost
Old Mar 9, 2013 | 08:31 PM
Chad149's Avatar
Chad149
Coolant test cost
Took my truck in for a few warranty quibbles today and told them to test the coolant. Was told ninety dollars to do so. Curious what others have been getting charged. Thanks for input guys!
Old Mar 10, 2013 | 06:39 AM
rob92761's Avatar
rob92761
go buy the test strips about $10.00 and do it yourself. if it needs the fuild to restablize it that is about twenty dollars.
Old Mar 10, 2013 | 09:39 AM
Painted Horse's Avatar
Painted Horse
You found a place to buy the test kit for $10? Share!
You can use the basic test strips to do the first couple of steps of the coolant test. But you usually need the full kit to do the complete test and know if you need to add the Coolant Rejuvinator. ( the part where you drop the tablet in the coolant sample and depending on what color it turns you choose which test strip to use for the final test)
To OP, My dealer charged me $25.00
Just ask what test they perform. The test are completely different than what used to be performed on the previous powerstroke engines.
If your coolant fails the test and needs the revitalizer, You can add the VC-12 coolant revitalizer, But the recommended dosage would take at least two quarts and they run about $12-$15 a quart.
Old Mar 10, 2013 | 10:02 AM
djousma's Avatar
djousma
Tablet in the coolant sample? My second test is a sealed test tube like container with a droplet of something it it, that you add a measured amount of coolant into. Then test with a different type strip.
Yours sounds like a different type of test than I have.
Old Mar 10, 2013 | 12:18 PM
The Hoot's Avatar
The Hoot
Must be different than mine too. Plus, that kit cost $50! I just used it for the first time last week.
When it comes to this (and many other things), I don't and won't trust the dealer.
Hoot
Old Mar 10, 2013 | 03:58 PM
desertnomad's Avatar
desertnomad
I didn't trust my dealer so I bought the Rotunda kits for $76 and did the tests myself. Tests turned out perfect. Very easy to do and the kits will last a lifetime.
328-00008 superseded by 328-R071-ELC
ANTIFREEZE COOLANT ELC CONTAMINATION KIT
https://rotunda.spx.com/en-US/Pages/...x?itemID=30172
328-00001 (3 Way HD Antifreeze Coolant Test Kit - 1 Bottle and 1 Kit)
has been superseded by 328-2050-62291
https://rotunda.spx.com/en-US/Pages/...x?itemID=30166
Old Mar 10, 2013 | 05:41 PM
mikespecht's Avatar
mikespecht
I was going to do this also, but if I remember correctly, the kits have some kind of expiration date on them. I can't remember where I read this exactly. It was about 2 years ago when I first got the truck.
Old Mar 10, 2013 | 05:53 PM
mikespecht's Avatar
mikespecht
On this post one of the the people states there is a two year self life on the strips.
https://www.ford-trucks.com/forums/1...dditive-4.html
Old Mar 10, 2013 | 06:07 PM
djousma's Avatar
djousma
These are the kits that I have too. Yea, the kits do expire, but does that mean they go immediately bad? I'll continue to use them.
Old Mar 10, 2013 | 08:13 PM
desertnomad
Ugh, looks like you're right about expiration. Damn, well maybe I'll do the check twice and every 5000 miles just to feel I'm getting my money's worth :-).
Old Mar 10, 2013 | 11:31 PM
Painted Horse
The kits have enough strips to do 10 test. Since you have two radiators, That means you get to test your system 5 times before you would run out of test strips. I drive enough that I'll do 5 test before the expiration date.
Old Mar 11, 2013 | 12:34 PM
rameyer's Avatar
rameyer
My dealer did the test for free.
Old Mar 11, 2013 | 12:50 PM
Chad149's Avatar
Chad149
Thanks for all the input guys. Technically this is the dealer I bought from but the owner sold out and retired after a stroke shortly after I bought last spring. I will check with another dealer I know guys at and see what I can get done. But if I can't do better I think I will buy the kits next time. At this price I will still come out ahead even if I throw some away.
Old Mar 11, 2013 | 04:38 PM
mikespecht's Avatar
mikespecht
The next time my light comes on I will probably buy the kits to test it myself. I don't drive the truck that much. I should get min 2-3 tests out of the shelf life. i also have to take into account my time that is required to take the truck in, the cost of the test itself, and the mark up that the dealer has on the revitalizer, if needed. I would like to think I would at leaste break even and save some time.
Old Mar 13, 2013 | 09:49 AM
don.joyce59's Avatar
don.joyce59
My dealer checked mine for free also. And I trust my dealer. If I didn't trust my dealer I would not have bought my truck there.
