2019 powerstroke fuel pump question
Old Aug 18, 2020 | 07:00 AM
fener6's Avatar
fener6
I had some ****tie luck yesterday and messed up the fuel pump on my 2019 f550 flatbed. I got 2 questions hopefully you guys can help.
There are two arrows on the top of the pump, one points towards the pump and the other away ( supply + return). Currently fuel is being pumped Out of the pump from the side with the arrow pointing into the pump (what I assume is the return). Should the fuel flow be following the arrows?
Second question, does anyone have a good picture of the connection going into the top of the pump? This connected is what got damaged, and I tried to put the 4 wires back where I thought they were...but maybe I have them crossed?
In the picture attached you’ll see how I connected the wires. And you’ll also see one of the arrows on the top of the pump...is that the supply line? Meaning fuel should be pumped out from that side (which it isn’t right now)?
Old Aug 18, 2020 | 08:26 AM
swampman1's Avatar
swampman1
Sounds like you have the wires crossed if the fuel flow is opposite of where it should be.
Old Aug 18, 2020 | 10:26 AM
fener6's Avatar
fener6
the two wires with brown plugs were crossed
lifted77f250
Jul 26, 2010 06:59 AM
DAI532
27
Sep 24, 2009 08:34 PM
Futuresweets-10
15
Nov 13, 2008 08:58 PM
bigbadwolfe
Apr 1, 2008 08:27 PM
executive284
Feb 23, 2006 06:56 PM
