Fuel pumps are a bear to get in place properly. Try to get the eccentric at the high position for the pump arm to lessen the force required to start the mounting bolts. Sometimes the inlet and outlet ports are marked. If not you can do a best guess and see what happens. Put a finger over the carb line to feel if there is pressue. I have done all those things then returned the pump.
I've had to actually turn my engine by hand on the crank bolt just to lessen the amount of pressure on the arm just to get the darn thing pushed up in place to bolt in. The stock replacement pumps are the hardest to get to the bolts especially the most rear one. I'm running a Carter model 9630 I believe that's a little easier to bolt up.
It turns out the fuel line from the tank to the pump had a kink that wasn't easy to find at first. After taking the pump off and looking it over, I decided to blow air through the line. It was appearant the line was plugged somewhere when pressure built up and blew back out at me.
