Sponsored by: Auxito
Coolant leak
Old Aug 17, 2020 | 06:47 PM
Samuel Foote's Avatar
Samuel Foote
Coolant leak
ok so first I replaced the water pump and thermostat both were necessary (water pump only had 3 fins on it out of i believe 9 or so and there was no thermostat in it) still losing coolant then I replaced intake gasket and ran a cold compression test all but 3 cylinders were dead up at 150 very front passenger side cylinder was 3-4psi low the third cylinder from the front passenger side was 2-3 psi high and one on drivers side was 2-3 high i am still losing coolant no water in oil no crystallization on spark plugs found where it is dripping on passenger front of exhaust manifold however I couldn't see where its coming from examined around the intake with a light and cannot see any water anywhere around it or in the valley of the block please help also it leaked about 2 ¼ gal in a day given i drove about 130 miles the leak i found doesn't seem to be more than about what ac condensate is normally slow drip
Old Aug 18, 2020 | 09:14 AM
steve(ill)'s Avatar
steve(ill)
see if it is running out of the bell housing between the motor and the transmission... There are a couple freeze plugs on the backside of the motor and may have a pin hole from corrosion.
Old Aug 18, 2020 | 09:17 AM
steve(ill)'s Avatar
steve(ill)
see photo in first post below.. You may have a different motor, but similar plugs
https://www.ford-trucks.com/forums/1...-question.html
Old Aug 20, 2020 | 06:12 PM
z31freakify's Avatar
z31freakify
Assuming it's a 4.6 or 5.4 these engines are notorious for leaking cross over on the intake manifold and engine valley coolant line to heater core line.
Old Aug 20, 2020 | 07:09 PM
ford390gashog's Avatar
ford390gashog
I am going with cracked crossover, everything you have is classic of it. Prone to cracks behind the thermostat.
ftv37
Aerostar
Feb 17, 2016 03:59 PM
Mikeman
1983 - 2012 Ranger & B-Series
Mar 4, 2012 10:47 PM
95X15
Feb 9, 2005 04:23 PM
woodworx
General Automotive Discussion
Oct 27, 2004 12:11 PM
markinms
Mar 3, 2004 07:12 PM
