Coolant loss - where's it going?
Old Feb 20, 2004 | 06:46 PM
markinms's Avatar
markinms
I'm having a problem with coolant loss. I add as much as 1/2 gal after a 300 - 500 mile trip. No visible external leaks. No coolant under the vehicle. No indication, by checking the plugs, that it's getting into any of the cylinders. No signs of coolant/water coming from the exhaust system. Any ideas where to look?
Thanks!
Mark
Old Feb 20, 2004 | 08:06 PM
Ultramagdan's Avatar
Ultramagdan
I would still do a compression test. These slow leaks can be a bearcat to track down. A small leak like that may not leave much of a indicator. It could be a leaking water pump, a hose with a small leak, a manifold gasket, etc.
Old Feb 21, 2004 | 10:02 AM
markinms's Avatar
markinms
Thanks for the feedback. I did a compression check and got 150 on 5 cylinders and 148 on 1 cylinder. I think I'm ok there.
A friend suggested I pressure test the radiator. I'll try that as soon as I'm able to and post the results.
Again, thanks for the feedback.
Mark
Old Feb 22, 2004 | 09:01 PM
jessfactor's Avatar
jessfactor
how do you do a compression test. i was always curious about mine.
Old Feb 22, 2004 | 09:04 PM
87MarkVIILSC's Avatar
87MarkVIILSC
it might only be leakin/burning when youre driving down the road. head gaskets, bad water pump, heater core, freeze plugs etc.
Old Feb 28, 2004 | 09:14 PM
bob arrington's Avatar
bob arrington
check your passenger side floor boardfor wetness,,bob
Old Mar 3, 2004 | 07:12 PM
bcf's Avatar
bcf
I just replaced the thermostat housing gasket on my truck. Had been leaking for months before I finally spotted it.
gabbie07
Jan 19, 2017 08:34 AM
nmclella
Dec 29, 2015 10:10 AM
johnwassink
Oct 15, 2015 02:37 PM
03powerstrokefl
Sep 9, 2014 07:27 PM
white dually 2001
Large Truck
Apr 29, 2014 05:07 PM
