Smoke on 60 Econo tune
#31
#32
Thanks Jason. That is what I thought except I didn't want to here that about new! Hope that is rare. I'd go to a 80 or 100 nozzle if I could get good tuning. But I want to be able to tow my tow hauler with no problems. I still like the power of my old engine building days in the 60's. It is fun once in a while!
#33
oops. It was me who recommended the billet wheel. I loved it. Spools very quickly. Maybe wrong on my part to think it might help clear up some smoke but it kinda depends when/where it happens. Off idle? Yeah you’re correct, it wouldn’t be able to clear it up much at first tip in. But I image it would clear it up quicker since it spools so much faster.
I do agree - the 4+4 wheel is a solid upgrade.
If you want more than 320hp in a tow tune, go to hybrids. A 238/80 will run just like a 160/0 - unless you want more power, then bump the chip a few times and traction becomes a real issue.
#34
#35
I just put in new alliant 160/0 injectors on my f350 and the truck runs amazingly smooth. I have jellibuilt tunes paired with riffraff 4x4 compressor wheel and kc s300 turbine wheel and the truck barely smokes at all. I think this has alot to do with the larger turbine wheel. In a 80 hp tune it will smoke if i stab the throttle but cleans up almost instantly. Very happy with this setup. I will be putting in the same injectors in my f450 tow rig once I recoup some funds. My dp tunes on my f450 have always been smoky, I have international bellowed uppies, s&b intake, riffraff 4x4 wheel on this truck as well and still smoky. No boost leaks either....
#36
Thanks Jason, I would like to do that, I noticed you do have Cody's tunes. Would love to do this with his tunes. I'd even drive out there. It is a ways but, I feel it would be worth it.
Jstihl, thank you to. That is what I probably will have to do also. Would love to have the extra power but where I am at that might be the best bet. Coming soon.
#37
I can second the new injectors being way better than remans.
Anywho... it's the tune, it's the tune, it's the tune. Nice HPOP! It's keeping up with some hard-core fueling demand.
That tune is like a sex change operation for your truck - it's now more your wife than your buddy. You can't punch it, you have to ease into it.
#38
#39
Chet
Djones2121
01-17-2013 06:05 AM
