Diff Oil Recommendations
Old Aug 16, 2020 | 10:00 PM
PDX_F250_78's Avatar
PDX_F250_78
Looking for diff oil recommendations? I know there is a lot of synthetic oils out now, what weight is recommend for our trucks? I have dana 60's front and back?
Also, what is everyone using to de-grease the covers for painting?
Thanks!
Old Aug 16, 2020 | 11:06 PM
440 sixpack's Avatar
440 sixpack
80-90 of your choice. I don't use synthetics much because they're a great leak promoter but they're good if you don't mind it. if you have trac lock add a friction modifier .
I use a wire brush on the grinder then bead blast the covers while they're off to clean them. but if you don't have those things any degreaser works better than nothing.
Old Aug 17, 2020 | 12:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on 89/90 gear lube. X2 wire brush and spray brake cleaner works pretty good.
Old Aug 17, 2020 | 04:20 AM
matthewq4b's Avatar
matthewq4b
GL-5 80W-90 a syn GL-5 75W-140 will work best if your truck is going to see severe service.
Old Aug 17, 2020 | 07:38 AM
Ozzie H.'s Avatar
Ozzie H.
Thanks!
I don't have the Ford books for '78. The '76 books ask for Hypoid Gear Lubricant meeting Ford specification ESW-M2C105-A (part number C6AZ-19580-B or E) for the Dana axles. If limited slip Dana, add 4 oz. of EST-M2C118-A (friction modifier part number C8AZ-19B546-A). I believe the one I used was SAE 90.
For the valve covers: Mine did not have any heavy deposits, so I washed them in diesel, wiped them down with some mineral spirits, straightened any distortions, then painted them with some gloss oil based paint.
pethjacob
13
Jun 5, 2014 08:44 PM
Brian3676
Jan 10, 2011 05:50 PM
chas4x4
Oct 8, 2009 11:57 AM
C350CREW
May 29, 2008 08:18 AM
Cold Man
May 28, 2007 09:01 PM
