Camber adjistment?
Old Aug 15, 2020 | 10:57 PM
Buck268's Avatar
Buck268
Camber adjistment?
I keep seeing various walk throughs and write ups talking about the cam nuts on our UCAs for adjusting camber. Ive done UCAs on both my 2011 4wd and my daughters 2005 2wd. Neither had any type of cam or adjustment for UCA alignment. Is this only an aftermarket piece or are both trucks missing these?
Old Aug 16, 2020 | 07:13 AM
RTM's Avatar
RTM
Not sure if there is an aftermarket upper arm like that for the F150's. But why would one need it when it's all done moving the lower arm. I would think with both arms being adjustable it would complicate an alignment process.
Old Aug 16, 2020 | 07:30 AM
RTM's Avatar
RTM
Found these arms. https://www.stage3motorsports.com/25...trol-Arms.html
Old Aug 16, 2020 | 09:37 AM
steve(ill)'s Avatar
steve(ill)
The upper control arms are movable on the OLDER FORD trucks.. The mounting holes in the frame are slotted. You can push the A arm in or out or twist somewhat to get the alignment... You DONT need the AFTERMARKET cam set to do this... but some shop like to install them during the change.... I have done 2001, 2002, 2006 trucks and not use the cam set.
150 Beast
2015 - 2020 F150
May 16, 2019 06:07 PM
chetspencer
May 7, 2017 03:11 PM
jonnydz
Oct 15, 2013 08:59 PM
OddManOut
Apr 1, 2003 08:45 PM
cubster
Apr 6, 2002 09:14 AM
