Door Lock Solenoids
Old Aug 15, 2020 | 02:04 PM
Cougar54's Avatar
Cougar54
Door Lock Solenoids
I am installing Altman latches so I need a remote entry unit and actuators. I am leaning on the Dakota Digital control unit but was curious what size (pounds of pull/push) I need in an actuator. They seems to vary from a few pounds to about 12 pounds for door locks and even higher of course for door poppers. Some actuators are electric solenoids while others are gear motors. Preference?
Old Aug 15, 2020 | 03:59 PM
burnettd01's Avatar
burnettd01
Cougar54
I purchased my door poppers from AVS. The kit is an 8 channel kit and I purchased the electric window controller from them as well. Door poppers work well with the Altman Latches. Haven't installed the controllers yet.
Hope this helps
Dan
https://www.avsontheweb.com/avs-shaved-door-kits
Old Aug 15, 2020 | 04:38 PM
Cougar54's Avatar
Cougar54
Originally Posted by burnettd01
Cougar54
Hope this helps
Dan
Dan, I was planning to only use the actuator for the door locks as I have the original outside/inside door handles so door poppers are a bit of overkill for the Altman locks which move very easily. I'm thinking a 10# pull/push is more than enough but I have no experience to know if my theory holds true.
By the way, do you remember where you found those wafer head metric screws? I have one just barely touching the primered door jamb. By the time I add the basecoat/clearcoat finish paint I'm sure I will have a problem. I did find some standard 1/4-20x3/4 SS wafer head screws at Fastenal but the head is about 3/4" in diameter. I'll use a M6-1.0x16mm metric wafer head if I can find them. I did not see them at McMasters.
Old Aug 15, 2020 | 05:08 PM
burnettd01's Avatar
burnettd01
I believe I bought the metric wafer head screws off of ebay. They were low cost. I just bought 6-1/4-20 ss wafer head machine screws for the latches at McMaster-carr. Haven't received them yet (Expensive).
Check them out. Worth it if it works.
Old Aug 15, 2020 | 05:28 PM
allout5151's Avatar
allout5151
Home Depot had M6-1.0 x 16mm https://www.homedepot.com/p/Everbilt...dalType=drawer
Old Aug 15, 2020 | 09:19 PM
Cougar54's Avatar
Cougar54
Originally Posted by allout5151
Thanks for taking a shot but those are bevel head and I need wafer heads. I appreciate the attempt though.
Old Aug 15, 2020 | 09:27 PM
allout5151's Avatar
allout5151
Oh Jeez, sorry about that. Better put my glasses on.
Old Aug 15, 2020 | 11:20 PM
burnettd01's Avatar
burnettd01
I forgot to tell you that McMaster-Carr calls the bolts ultra-low profile stainless steel bolts. I haven't received them yet but they should work.
Take care
Dan
Old Aug 16, 2020 | 11:35 AM
Cougar54's Avatar
Cougar54
Take care
Dan
Thanks
Old Aug 16, 2020 | 06:51 PM
Okiedokie's Avatar
Okiedokie
I bought mine from LMC, just generic electric door lock actuators. Work fine.
Old Aug 16, 2020 | 06:55 PM
Cougar54's Avatar
Cougar54
Are you using them on an Altman latch?
Old Aug 17, 2020 | 07:13 AM
Okiedokie's Avatar
Okiedokie
Yes with Altman
fcctobe1
Dec 21, 2012 03:50 PM
jjs2032
Apr 22, 2008 08:27 AM
93F250
Jul 26, 2007 07:54 PM
frazier23727
1997 - 2003 F150
Jun 5, 2004 09:02 PM
