Turn signals?
Old Aug 13, 2020 | 07:36 PM
Bob Ingram's Avatar
Bob Ingram
Turn signals?
So I just found out that I have no brake lights on my 48. After an hour of troubleshooting I’m pretty sure it’s the turn signal controller. I have voltage all the way to the controller when I step on the brake, signals work as does the running lights. My conclusion is that the switch on the steering column is f##ed.
what is the recommendation for a replacement?
Old Aug 13, 2020 | 08:34 PM
52 Merc's Avatar
52 Merc
The unit you have is popular and usually very reliable. Chances are if you were to open it up, you could probably see what's wrong and fix the loose or broken wire and be good to go. They are simple inside.
Old Aug 13, 2020 | 08:54 PM
abe's Avatar
abe
So, Bob, you bought the truck? Awesome.
Start a new thread and fill us in.
Old Aug 13, 2020 | 09:06 PM
FortyNiner's Avatar
FortyNiner
I had one of those switches (or a version of it) on another project. I chased my tail for a while trying to troubleshoot the issue. Never could fix it - even after opening it. Find a Signal Stat 900 and install it. No regrets.
Old Aug 13, 2020 | 10:35 PM
Mixer man's Avatar
Mixer man
Congratulations, Bob. How many wires on your turn signal switch?
Old Aug 14, 2020 | 12:40 PM
Bob Ingram's Avatar
Bob Ingram
Thx guys for the responses. Turned out to be an easy fix. The thingy wasn’t screwed down to the whatsit enough and the springy things weren’t touching the hoosits.
ok...the piece that rotates to make contact with the fixed piece was loose. Tighten the screw and everything made contact.
Old Aug 16, 2020 | 07:30 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
I like your first description better!
Old Aug 17, 2020 | 07:18 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Yeah, but some people don’t understand that technical engineering jargon.
F151
Dec 27, 2017 01:58 PM
learpilot
May 14, 2016 09:43 AM
allwthrrider
Jun 28, 2011 06:28 PM
ajford
Jul 17, 2010 08:29 PM
BigGrizz76
Mar 3, 2008 10:10 PM
