Ignore wrong forum...Sorry
Old Aug 14, 2020 | 04:41 PM
Kenneth Maddux's Avatar
Kenneth Maddux
Replacing the Ball joints on my 1992 f150 step side 4x4. Son decided to help and tore it apart and cannot remember how to put back together!!! I bought a Haynes online book and that damn thing has no pictures and no diagrams! Basically I need from locking hub to the stub shaft. I do not want to miss anything. Anyone please help? I do not want to forget any clips or washers etc. So afraid.
Thanks!
Where to go?
Last edited by Kenneth Maddux; Aug 14, 2020 at 08:10 PM. Reason: Wrong forum. Sorry
Old Aug 14, 2020 | 07:02 PM
projectSHO89's Avatar
projectSHO89
Go look at the other side, assuming he didn't tear it apart at the same time.
I'll attach the service manual procedures in couple of minutes. [Done]
File Type: pdf
Old Aug 14, 2020 | 07:03 PM
ford390gashog's Avatar
ford390gashog
Well I am really confused, that is not a 2009 F150 knuckle. All the trucks I have done are all 4 bolt flange for the wheel bearing assembly. Plus they don't have forward mounted tie rods and the brake calipers mount with pins not slides. What are you actually working on?
Old Aug 14, 2020 | 07:22 PM
Kenneth Maddux
Sorry 1992.
Old Aug 14, 2020 | 07:24 PM
Kenneth Maddux
Sorry it is a 1992. The other one I have is the 2009
Old Aug 14, 2020 | 07:28 PM
Kenneth Maddux
That is what I was looking for. Have it for 1992? That would really help.
Old Aug 14, 2020 | 07:39 PM
projectSHO89
I have it for a 93-94 truck which is probably the same as the 92, but it's on an older system that isn't handy at the moment. Oldest I have on this system that is immediately available is the 96 truck collection. I have no idea whether or not it's applicable to your 92.
Old Aug 14, 2020 | 07:49 PM
gDMJoe's Avatar
gDMJoe
Lightbulb
Kenneth Maddux - Replacing the Ball joints on my 1992 f150 step side 4x4. ...
  1. This is the 2009 - 2014 F150 forum.
  2. » 1987 - 1996 F150 & Larger F-Series Trucks
Kenneth Maddux
Well if you have the time would be great. Thanks for your help
Old Aug 14, 2020 | 08:09 PM
Kenneth Maddux
Yeah I screwed up been a long day. Sorry
Old Aug 16, 2020 | 05:45 PM
JKBrad's Avatar
JKBrad
I'll move this to the correct forum.
Old Aug 16, 2020 | 09:02 PM
torq'ta 5 8's Avatar
torq'ta 5 8
auto, manual?
this may help, link below
courtesy steve83
1983 Ford Bronco Brakes & Hubs pictures, videos, and sounds | SuperMotors.net
Old Aug 16, 2020 | 09:07 PM
Scndsin's Avatar
Scndsin
Go back to your first post. Click the "edit" button, then "go advanced".
It will give you access to the title bar & you can change it since you're where you should be.
fall4curt
May 31, 2016 08:41 PM
HD RULES
Aug 30, 2011 01:19 PM
ktgraf
Jan 20, 2008 05:17 PM
bjbmoglo
1978 - 1996 Big Bronco
34
Sep 23, 2004 01:40 PM
bjbmoglo
Aug 8, 2004 06:00 AM
