Heavier than I thought
Old Aug 12, 2020 | 08:22 PM
Thursk01's Avatar
Thursk01
2020 F-350 Diesel CC 4x4 short bed. Lariat with all options other than chrome package and 5th wheel prep.
7830#
3/4 tank of fuel and 1/2 tank of Def. B&W turnover hitch and a few items under the back seat....
I subtracted the 3 passengers on board out. Leaves me with a little over 3600# cargo capacity.
these are some heavy trucks!
Old Aug 12, 2020 | 09:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
7830#
That is part of what makes them good towing rigs.
Go heavy or don't go.
Old Aug 12, 2020 | 09:07 PM
Thevol's Avatar
Thevol
Imagine if it wasnt aluminum!
Old Aug 12, 2020 | 09:12 PM
crewzer's Avatar
crewzer
Lightbulb
7830#
Sounds about right. The official Ford curb weight for your truck configuration in base trim with no options is 7486 lbs.
Your truck’s official payload spec (passengers and cargo) should be stated on the Tire and Load Label on the driver side B pillar.
Safe travels!
Jim / crewzer
Old Aug 12, 2020 | 09:14 PM
Thursk01's Avatar
Thursk01
totally agree! More than whatever engine these SD’s have, it is the rest of the package that makes them so solid and stable for towing
I’ll never go back to a 1/2 ton
oh, and glad I got the 350 for the extra GVWR
Old Aug 13, 2020 | 07:33 AM
speakerfritz's Avatar
speakerfritz
that would make it a commercial vehicle registration class in NY
Old Aug 13, 2020 | 08:35 AM
smokewagun's Avatar
smokewagun
It would barely matter. If you recall, almost all the weight savings when Ford jumped to aluminum bodies went back into the frame. The net savings was barely 250 pounds.
Old Aug 13, 2020 | 03:28 PM
1olddogtwo's Avatar
1olddogtwo
Right, Net saving.
aluminum switched had saved 750lbs, the added 500 was heavier running gear........
Marketing people.
Old Aug 13, 2020 | 05:11 PM
System's Avatar
System
Prolocutor
My truck with full fuel (55 gallon Titan tank...), 5th wheel hitch in, and the 3 of us was about 1000# more. I was heading towards 9k before hooking up.
Old Aug 14, 2020 | 07:16 PM
AUTOHAUL's Avatar
AUTOHAUL
Took my 2020 F350 XLT Crew DRW 4x4 7.3 from the show room floor to the gas station filled it up then to the certified scale.
# 7800 empty
# 4300 front
# 3500 rear
a little suspicious of the even numbers but it was a certified scale. I think there's plus or minus #20.
Old Aug 15, 2020 | 04:36 AM
Drothgeb's Avatar
Drothgeb
My 2020 F350 7.3 SCLB SRW outfitted for hauling the truck camper came in at a lean #7980.
Old Aug 15, 2020 | 06:03 AM
PlanoRob's Avatar
PlanoRob
# 7800 empty
# 4300 front
# 3500 rear
yep, I get round numbers on CAT scales, too.
Old Aug 15, 2020 | 09:25 AM
Freqz's Avatar
Freqz
My 2017 DRW 6.7 is a thic girl...full tank of fuel, my small low profile tool box, me and precisely 400# of stall mats in the bed.
MrAgent007
Oct 8, 2018 05:43 PM
ssunit1
All Things Towing
18
Jul 11, 2016 12:55 AM
garyalton
Sep 10, 2014 07:30 AM
rsyauto
6.7L Power Stroke Diesel
Nov 12, 2013 12:57 PM
gmenfan
Nov 28, 2010 08:01 PM
