Sponsored by: Real Truck
Windshield Washer
Old Aug 11, 2020 | 09:16 PM
WittorfJ's Avatar
WittorfJ
4wd Low
Windshield Washer
Does anyone know the fuse/relay location for the windshield washer on a 2015 F350? Mine quit working, can't find a location for the washer motor fuse. Wipers work in all positions. No listing for windshield washer fuse in my owner's manual.
Old Aug 12, 2020 | 09:46 AM
Just Strokin's Avatar
Just Strokin
I don't believe there is a separate fuse for the washer. You might have a bad multi-function on the steering column. It controls, wipers, washer, blinkers etc.
Old Aug 12, 2020 | 11:00 AM
lowflyer001's Avatar
lowflyer001
Yes, the washer pump is powered through the wiper / muti-function switch (lever.)
Pull the pump connector out, test light the circuit. Most likely its in the switch, but I've seen the connector at the pump get corroded or deteriorate
Old Aug 12, 2020 | 11:10 AM
seville009's Avatar
seville009
Some simple things in this thread to check first
https://www.ford-trucks.com/forums/1...t-working.html
AbandonedBronco
1978 - 1996 Big Bronco
Oct 12, 2013 06:03 PM
RRranch
Feb 6, 2011 05:29 PM
tenforty_2
Apr 12, 2010 10:15 PM
