Sponsored by: Real Truck
Windshield washer fluid pump not working
Old Nov 5, 2011 | 01:22 PM
fenderfuel's Avatar
fenderfuel
Any ideas? I haven't heard of these failing. Does anybody know if its maybe a fuse blown and if so which one? I looked in the owners manual and I'm not sure. I also have a block heater cord that had been cut and someone told me that they cut the end off when the block heater fails. I checked the oms between the two leads and it read 29.7oms. Someone told me that it should be closer to 0oms so if anyone could comment on that too.
Thanks,
Dan
its a 2003 F250 6.0L Diesel
Old Nov 5, 2011 | 01:36 PM
jamestheron08's Avatar
jamestheron08
mine quit to got pist and smacke the switch then it started working
Old Nov 6, 2011 | 01:27 AM
fenderfuel's Avatar
fenderfuel
yep tried that... didn't work.
Old Nov 7, 2011 | 12:23 AM
fenderfuel's Avatar
fenderfuel
Figured it out... I had my wife listen for the wiper fluid motor to turn on and she could hear it when I pressed the button. Followed the hoses and found one was kinked just under the plastic cover below the windshield.
Old Oct 2, 2012 | 04:36 PM
ksch994462's Avatar
ksch994462
I think you just solved my problem. My nozzles spit out a little, so I know the pump is at least working. I'll bet it's a kinked hose. Thanks...
Old Oct 2, 2012 | 05:43 PM
mikeismadness's Avatar
mikeismadness
Kinked hose! Mine did the same today lol
Old Oct 6, 2012 | 11:32 PM
DBubba's Avatar
DBubba
Windshield Washer Not Working
I too had a problem with my windshield washer not working (of course he rear washer would work). I pulled the battery and washer resevior, inspected the pump, it would only pump the rear not the front windshield. I replaced the pump and still the unit would not operate.
I took it to my buddy who is a master mechanic and he found that one of the relays in the relay box under he hood had failed. He replaced both and they work perfectly. Lesson learned check the relays after the fuses and make sure that they are good before you go any further. When you depress the wash switch you will hear a click if the relay is good.
Good Luck!
Old Oct 7, 2012 | 10:20 AM
Rudiak's Avatar
Rudiak
I had the same problem. I could here the pump but no spray. Pulled right headlight to get to pump. Pulled out pump and foung it clogged with what I would describe as blue gum. Cleaned it off and re-installed. Good to go.
Old Oct 7, 2012 | 04:53 PM
Yahiko's Avatar
Yahiko
When I got my truck in March one of the outlet was giving me problems.
So I remove the the inlet grill just below the glass and unhooked the
hose and got a nice squirt. I thin just removed the old nozzle and
put a now on it it's place. Works nice now. Lesson is if you have a
plugged nozzle unhook the hose and run to clear out any dirt in the line.
On the block heater 0 ohms would be too low 10-24 Ohms
@ 10 Ohms you have about 1440 watts and @ 24 Ohms you
would only have 600 watts Where 3 Ohms would give you 4800watts
and the amperage would be 40Amp more that a house plug can handle
The one at 10 or 11 Ohms would be you best bet at about 1440 Watt
and 12 Amp.
You can replace a bad plug with a replacement kit. Like this.
Ford 7.3 6.0 6.4 6.7 L Powerstroke Diesel Block Heater Cord F350 F250 Excursion | eBay
But you need to test the element to see what the resistance is and
also check one of the leads to the block on the Meg Ohm range that
should show like an open circuit otherwise you will have current leaking
to ground by way of the coolant and that is not good. If plugged
into a GFCI it will trip to keep you from getting shocked and that could kill
someone. That would not be good.
Sean
Bigbb27
2009 - 2014 F150
Jan 5, 2014 11:03 PM
roller_steve
Sep 28, 2011 03:36 AM
YoungFordAddict66
Feb 9, 2011 07:34 PM
WINGNUT-
15
Jul 31, 2010 10:49 PM
madspence2
Oct 14, 2004 03:12 PM
