dreaded drained battery
Old Aug 11, 2020 | 04:18 PM
blackestate's Avatar
blackestate
so this new to me 2011 has a 2.5 amp draw. have been checking and can not find it.
I removed all the fuses in both panels one at a time, and it still has the test light lit up at the negative cable to battery. i was checking to see if the dash was still lit, or if i could see that in the day light. and i am not sure about that.
I did notice that when i turn the key off, the tach and speedo drop below 0, and then about 15 seconds later, when the blue lights turn off, they jump back up to zero. is this normal? or should they stay below zero, and the dash is powering back up for some reason.
Old Aug 11, 2020 | 04:24 PM
ford390gashog's Avatar
ford390gashog
Thats a symptom of low chassis voltage drop and a BMS issue. How old is the battery? The 2.5 amps you see is indicating a BCM pulsing and it will do that below 11.3 volts.
Old Aug 11, 2020 | 05:09 PM
gDMJoe's Avatar
gDMJoe
Arrow
Known (but not limited to) causes of battery drain ...
Old Aug 11, 2020 | 07:34 PM
blackestate
i do not know how old the battery is. i put a charger on it separate from the truck. after it was charged, i am now at .27 amps. and a steady 0.27.
I have read that list in multiple places. am i right to assume that the ones with the arrows are more likely to be the issue? also i notice that wen i put the key in, if i do not turn it, the power seat moves forward and backward like i am putting the key in and out. would that line up with that being the cause?
maybe because the battery was so low i was getting a lot of the BMS cycling, and making my fuse test not so valid?i think i will put a new battery in it, and then check it. the truck is new to me, it is a motocraft battery, but no idea how old it is.
If i have a good battery is 0.27 normal?
Old Aug 11, 2020 | 10:26 PM
gDMJoe's Avatar
gDMJoe
blackestate ... am i right to assume that the ones with the arrows are more likely to be the issue?
Most common, Yes. But ... Could be any of 'em or even something not listed.
It's not a cause (unless you leave the key -IN-). By inserting and withdrawing the key (without opening and closing the door) the BCM (Body Control Module) is essentially still -hot- and -cycling- for 15-minutes. meaning: can use radio, power windows, HVAC, etc.. Taking the key out, opening, and closing the door shuts-down the functionality.
It's also a good ROT (Rule Of Thumb) to turn-off the radio, HVAC, as well unplug anything from the 12V receptacles, and turn-off/disconnect any after-market electrical add-ons BEFORE turning-off and removing the ignition key. *Would also consider turning-off the headlights' auto-lamp (but that's just me).
And in doing all this, since purchasing my 2011 FX4 new in Oct/2011, have never had a BMS issue and still have the original Motorcraft battery.
Old Aug 11, 2020 | 11:23 PM
blackestate
I found a video that said that i needed to set up the amp check and wait 45 min to an hour so all modules would be a sleep, after 1 1/2 hours the amp reading is around 2 mA. so i think that is good. i left the battery disconnected, and will check it in the morning.
i do not use the auto lights, and do not have anything plugged into the outlets. and the truck is stock, just new to me.
There is a sticker on the side of the battery that says 9/14. guessing that is the MFG date.
hoping that it is just the battery i will update with what happens.
Thanks
Old Sep 2, 2020 | 08:34 AM
oldfordcoupe's Avatar
oldfordcoupe
had a problem with batt. going down r/r then again with in 10 days had to repl. batt again? finally took truck to dealership though i had a problem after they r/r the pwr. steering gear it quit ford shop said i had tow bad batt. they r/r the 3rd one and reset the batt montier? said that was drain the batt. that i r/r we will see
Old Sep 2, 2020 | 04:49 PM
gDMJoe's Avatar
gDMJoe
Exclamation
oldfordcoupe ...
HINT/TIP: Put your vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Edit Signature
Without capitalization, punctuation along with misspelling the post is difficult to read and understand.
Old Sep 10, 2020 | 01:58 PM
oldfordcoupe
well the saga continues the batt issue with my 2014 f150 now it has been one month when this all started it was with a advance trac warning plus no power steering. towed to dealership r/r power steering gear? they said all good next day slow to start plus no rear camera three days later batt. down no start, warnt. good on batt repl. same it lasted almost a week, r/r batt agin lest than week later batt down again. jumped truck off took to ford dealership complained about last 3 batt. they had it 3 days they r/r batt again adj. batt monteier? said it was good . last sat truck no start. thusday had it towed to dealership told the to fix it talker to service mgr. gave me rental to drive waiting for call????
MyName1sMud
39
May 11, 2012 09:41 PM
jake5454
Aerostar
Jun 5, 2010 11:10 PM
RussB
Sep 14, 2009 12:33 AM
lowbed dud
1997 - 2003 F150
Apr 12, 2008 10:30 AM
cdolor
Feb 19, 2005 02:43 PM
