So, my speedo is definitely off because the 275-65 R18 circumference setting from the factory is wrong for my tires.
My vehicle is a 2016 Expy and when I look at the values in the BCM as-built, 726-12-01 is definitely not the place for tire circumference.
Based upon what I read, 2015-2017 are supposed to be the same location.
Has anyone with a 2016 changed circumference?
Is there a spreadsheet for the 2016?
Does anyone have the location to change?
This spreadsheet has a lot of info for other Fords that might cross over between models, have a look thru all of them and see if any work for you. https://docs.google.com/spreadsheets...gid=1639495357 scroll down a little bit in the common tab.
Interesting. I wonder if my 2016 uses the locations from that spreadsheet because it was a late 2015 build...
726-12-01 is definitely not tire circumference in 2015. It's "use parking lights as drls"...
That's what I said, I was getting wrong information!! Geez man, lighten up.
Time and time again I read in threads on different forums that 2013 and earlier could not be reprogrammed with Forscan. My post above was to say that 2013 can be done, I did it.
Forscan and the license are free, nothing to buy. Please don't spread misinformation.
Sorry if I came off harsh, that was not my intention. I appreciate you and anyone else's input. Not sure what information I may have misrepresented, just shared my first hand experience.
It's cool, we all have bad days. I just felt the need to come back to this thread and gloat a little. Took me what seemed like forever to figure it out so I hope to help others.
