1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
D.S.O. question
Old Aug 13, 2020 | 07:53 PM
BobbyFord's Avatar
BobbyFord
Is there a part number on the frame brackets for the overload springs?
Old Aug 14, 2020 | 03:09 PM
braidy boen's Avatar
braidy boen
I don't know, but I will look. I'm going to have to wire brush the area pretty heavily to work through the rust.
I'll let you know what I find.
Old Aug 14, 2020 | 03:11 PM
braidy boen
That makes complete sense. I'll so some scrubbing, and then look around at what I find. I get the feeling I may need to wait until I get the body off the frame to look around effectively.
Old Aug 14, 2020 | 03:15 PM
braidy boen
1/4 of your trucks seems to me, to be a high number. Does that strike you as high also?
Old Aug 15, 2020 | 09:39 AM
TA455HO's Avatar
TA455HO
Lead Gopher
1948/62's do not have the first two digits of the DSO code listed. 1963 thru today: These codes refer to the specific FoMoCo district sales office where the dealer ordered the truck.
I have a number of 1962 trucks with a 6 digit DSO. Here's one example that you decoded of a 1962 with a 6 digit DSO.
https://www.ford-trucks.com/forums/1...1962-f100.html
Here's a 1962 4x4 with 6 digit DSO
https://www.ford-trucks.com/forums/1...formation.html
And an F250 with 6 digit DSO
https://www.ford-trucks.com/forums/1...n-project.html
It wasn't every special order truck but it was not uncommon.
Old Aug 15, 2020 | 10:02 AM
TA455HO's Avatar
TA455HO
Lead Gopher
When Ford installed the overload springs and brackets they typically rivetted the brackets to the frame. There are two things about these overloads that strike be as not being factory installed. The lack of rivets on those brackets - seemingly bolted to the under edge of the frame - and the leaves seem to be very squared off on the ends of each one on just the overloads. The original Ford leaves seem to have slightly rounded tips and tapered some, too. So, it might have been sent out to have those installed under a DSO, but no way to really know one way or the other most likely.
Old Aug 17, 2020 | 09:27 AM
braidy boen
Hi TA,
You have a great point. I'll use Number Dummy's thoughts on trying to find part numbers, and your thoughts on the assembly and see if I can't come up with some idea on the springs.
Also, the examples you sent of the 6 digit DSO codes are interesting. With all of them being either 250's or 4X4s, I wonder if those specific types of trucks had that type of coding when compared to the F100.
Old Aug 17, 2020 | 09:49 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The first example I gave was an F100. Here's that one again, but it's not the only one, either.
Old Aug 17, 2020 | 10:30 AM
braidy boen
Oh yeah, I missed that.
Very cool.
Old Aug 25, 2020 | 01:24 PM
braidy boen
Hi TA,
You were right on the money with your analysis of the second set of springs. They do not appear to be factory installed. They actually have GM stamped on the edges of many of the springs.
I appreciate your insight.
Braidy
robert_l_ross
Feb 22, 2020 01:45 PM
1Fastboy
Jul 31, 2015 10:19 AM
btdigital
Aug 6, 2011 02:12 PM
faulkz
Mar 14, 2008 11:45 AM
lanechange
Feb 29, 2008 02:01 PM
