Programming 2016 XLT after installing tow mirrors
Old Aug 18, 2020 | 02:34 PM
390XR7's Avatar
390XR7
I'm going to get my guy to try this on my 18 to see if this will get my puddle lights enabled. Anyone know what needs to be changed to get the spot lights enabled as well?
Old Aug 18, 2020 | 03:57 PM
Ken Newman's Avatar
Ken Newman
It should work if you have the 22 pin mirror connectors on your harnesses. The truck we copied was a 2019 with factory tow mirrors.
I'm not sure what's needed to make the spots work except the dash switch, another module and another harness for that switch.
Old Aug 18, 2020 | 11:23 PM
ford390gashog's Avatar
ford390gashog
Have you already installed the spotlight module and switches?
Old Aug 19, 2020 | 01:35 PM
390XR7's Avatar
390XR7
I have the module and switch installed but when he ran into trouble with the puddle lights he stopped there.
Old Aug 19, 2020 | 01:38 PM
390XR7's Avatar
390XR7
yes they are already installed.we went through the modules and #s according to the above and all mine match up with what's listed and the puddle lights still won't light up.
Old Aug 19, 2020 | 01:41 PM
ford390gashog
So with a 2018+ truck there is a wiring difference. After February 26th 2018 the ambient temp sensor was relocated to the passenger mirror. Are you using compatible mirrors?
Old Aug 19, 2020 | 01:45 PM
390XR7's Avatar
390XR7
The mirrors I'm using are off of my 2016 that I traded in on the 18.I have the 18 wiring installed because it was different then the 16 wiring I had.these mirrors are not tow mirrors but the normal ones.
Old Aug 19, 2020 | 01:46 PM
ford390gashog
You will need the 18+ passenger mirror for this to work due to the ambient sensor in the mirror.
Old Aug 19, 2020 | 01:48 PM
390XR7's Avatar
390XR7
Just the passenger mirror or both?
Old Aug 19, 2020 | 01:52 PM
ford390gashog
Just passenger mirror, take a look at your original. Is the IAT in the bottom of it?
File Type: pdf
Old Aug 19, 2020 | 01:57 PM
390XR7's Avatar
390XR7
My original mirrors are non folding manual ones.I had a look at the bottom of it and didn't see any sensor there
Old Aug 20, 2020 | 03:09 PM
390XR7's Avatar
390XR7
my truck was built prior to this,
Feb8th,
does this still have an affect on which mirrors I need to use?
Old Aug 20, 2020 | 03:29 PM
  #28
ford390gashog
Means you should be able to use your 2016 mirrors. Send me a PM with your email and I can send you all the files to compare.
AzSuperDuty
Feb 17, 2013 06:47 PM
bigtuna128
Jan 17, 2012 05:48 PM
JCark
Jan 9, 2009 10:21 PM
llcustom
May 27, 2008 10:54 AM
labenske
Mar 7, 2007 12:29 AM
