Re installed Injectors
Old Aug 4, 2020 | 11:49 AM
Adrod's Avatar
Adrod
Currently installing new heads on my 6.0 after blown head gaskets. Replaced all O rings and crush washers when putting in new injectors. When I was done I had one crush washer left over.
Even though I new I put them all on I wanted to make sure so I removed the 4 injectors that I already installed and torqued to 28 ft lbs. Of course all the new washers were there. The package had one extra washer.
Anyway I re-torqued the hold downs. The heads are back on the truck but I haven’t Installed oil rails or valve covers yet. Question is am I good or should I replace the crush washer since it was already torqued once? Was thinking of just re torquing them to 30 lbs .
Thanks
Old Aug 4, 2020 | 01:25 PM
bismic's Avatar
bismic
IMO the copper washers are one-time use only.
Old Aug 4, 2020 | 02:31 PM
Adrod's Avatar
Adrod
Thanks, yeah better safe then sorry. At least there easy to get to right now.
Old Aug 4, 2020 | 09:07 PM
BstangBill's Avatar
BstangBill
I would not over torque them. You might distort the hold downs. Seems that I read that somewhere.
Old Aug 4, 2020 | 10:08 PM
xcrsp440's Avatar
xcrsp440
Where did you get the injectors?
Motohead911
Sep 7, 2019 10:17 PM
Blueforester
Dec 10, 2017 02:45 PM
ljutic ss
May 26, 2008 07:05 PM
MagKarl
Jun 19, 2007 09:54 AM
