Trailer Running Lights Not Working
Old Jul 29, 2020 | 12:34 PM
AllaboutMPG's Avatar
AllaboutMPG
location of Instrument panel relay block, although I think you already know where it is. located bottom center
Old Jul 29, 2020 | 01:01 PM
Jacob Johns's Avatar
Jacob Johns
Originally Posted by AllaboutMPG
Looks like the brown / white wire leaves the relay and goes straight to the back of the truck. Would be nice if you could find it in the cab and verify if power is coming from the relay.
im not sure where you got the schismatics from but thank you so very much!!! once this rain lets up im going to chase wires!!!
Old Jul 29, 2020 | 01:38 PM
kbeefy's Avatar
kbeefy
Those are the same diagrams I have on ProDemand, I believe AllData has the same ones.
Old Jul 29, 2020 | 03:24 PM
AllaboutMPG
Bingo......
Old Jul 29, 2020 | 03:56 PM
Walleye Hunter's Avatar
Walleye Hunter
I just wish I could read those things. I'm like a blonde looking at a road map when it comes to electrical schematics.
Old Jul 29, 2020 | 04:23 PM
RA101725's Avatar
RA101725
Banned
Should be the brown wire running to the back of the 7 way for trailer running lights IIRC. Sounds like you have partial function if the stop and turn signals are working so I am guessing you have a bad connection or burnt wire just on that one circuit. Test the individual prongs on the truck outlet with a test light or buy one of those circuit testers from an RV or trailer shop for $20 or so. (Handy dandy little tool). Not sure I'd recommend running the whole trailer running lights off the license plate light circuit. It could be okay but if the amperage is too high you can blow the fuse or melt the wiring on that.
Old Jul 29, 2020 | 04:30 PM
RA101725's Avatar
RA101725
Banned
They've never done me much good either.
Unless the plug in the pickup bed was factory wired it's usually maximum cringe factor when somebody hacks into the factory wiring to add the bed plug.
78pace
Apr 19, 2020 12:09 AM
BassFantasizer
Feb 11, 2014 07:27 AM
sammie0126
1997 - 2003 F150
46
Dec 3, 2013 05:10 AM
grey1169
Apr 13, 2009 01:48 PM
fordguy21
All Things Towing
Feb 27, 2005 09:26 PM
