Running Lights on Trailer not working
I have a 97 Expy with 142K miles on it. I purchased a new travel trailer and just recently picked it up from the dealer. All the trialer lights worked on it.
I went to move the trailer the other day and the running lights on the trailer do not work. Turn signals work, brake lights work. The running lights do not.
I pulled fuses and all of the check good with an voltmeter. I did some more research and I found out that in the engine compartment there are some relays. I moved all of the relays to different sockets to see if one was failing and I still have the same issue.
The connector on the truck looks great All of the wiring that I can tell looks good also.
I even went so far as to jumper the hot and running lights on the camper (an campground trick I am told) to light up the trailer to check the circuit there. They all work also.
I am out of options and want to camping but cannot without the safety of the lights
HELP!!!
RoG
HELP!!!
RoG
I have checked the femail end of the connector and there is no power getting to those pins. I have followed the wiring harness up to the pigtail and the connectors and wires all look great. I see that the wiring harness goes up behind the evaporator for the AC and then towords the front of the truck.
Any other ideas? Fuses good. Wiring good. Connecotors good. I swapped the relays around in the engine compartment and they all behaved the same. HELP!!!!!
First off, I really should do a spell check before I post!
I was able to find the relay the powers up the running lights. It clicks every time that I turn the head lights on. If I pull that relay the headlights still work so I am guessing that this is the correct relay.
I swapped this realy with another of of the same part number (there are several next to each other in that box) and I still do not have any running lights.
I would gather then since the fuse is good and the realy is working that I have a wiring problem.
Does anyone have a wiring diagram or ping outs from the back of the vehilce to the fuse/relay panel?
Did you specifically check fuse F1 (20A) in the large under-hood fuse box? That is the one that protects the trailer running lamp circuit.
Here's a link over at the sister site regarding this same fault on a 150. The circuits are identical.
http://www.f150online.com/forums/ele...t-working.html
Steve
Steve
Hazmat 67
13
12-02-2019 01:32 PM
Al's_F600
20
04-18-2017 06:53 PM
00BlueOvalRanger
1999 to 2016 Super Duty
29
02-28-2014 06:10 PM
