overheating 75 supercab
Old Jul 29, 2020 | 11:33 AM
somethingclever's Avatar
somethingclever
Originally Posted by ford390gashog
Trans cooling circuit is routed as follows and is the way its done by all oem manufacturers.
Trans to radiator
radiator to aux cooler
aux cooler to trans
This allows the hot output from the trans to drop the most heat to the radiator and also always the coolest return to the trans. If you go as prescribed above you lose the initial high temp cooling ability. You actually heat the fluid to coolant temp before returning to the transmission which isn't good. The gauge doesn't belong in the cooling circuit unless you have two gauges and are measuring cooling deltas. The gauge needs to be in the pan or some install in the test port. Remember the C6 has no lock up so torque converter output temp can be up to 70 degrees higher than sump temperature.
If the OEM's do it that way, hard to argue.
However, it is my understanding that just like engine oil temps, transmission oil temps also have a sweet spot.
By design, this is close to the engine coolant temp, or around 180-190F. The reason to hit the rad cooler last is because there is the best chance to get your trans temp closer to ideal, which could mean to actually increase the trans fluid temperature if the aux cooler is too large.
Old Jul 29, 2020 | 01:14 PM
bluovl's Avatar
bluovl
What about fan and shroud spacing? When I was running a stock clutch fan on my Bronco it worked best when the fan was located just inside of the shroud. Not to close to the radiator. Also the rubber deflectors on the core support are critical to forcing air through the radiator and not around it.
Old Jul 29, 2020 | 02:10 PM
matthewq4b's Avatar
matthewq4b
Originally Posted by 1962galaxie
Ok,
I've tried adding fuel, its only a 2bbl so its pretty straitforward. No change. I also have tried more or less ignition timing, no change. It has a pertronix, so I think that's pretty reliable too. I haven't put in a timing chain, but it doesn't have much slop, so I think that's a reach. I'm going to start with a RS stat, and I think I might put the puller back on it that I already have. That won't give me room for a clutch fan though, so either back to the OE fan (my first choice) or nix the puller and go to a clutch fan? Votes? To the reply above, I've often wondered about the flex fan at speed, because I've been suspicious that it created turbulence and hurt air flow.
For the records: Coolant is very clean, I've had the heads off a few times, and I can vouch for the block and the flush. I've added surfactin as a crazy try also. I will add a trans temp guage, and I think this might be part of my problem, but I'm nervous that the trans temp will be pretty high with only an air cooler. Might try it and see.
I've got a rollback made out of a 64 f-350, with a healthy 312, 4spd, 3.73 gears. Been through the mountains over 20,000lbs with that a bunch, and Ive got nearly 300k on it now with only a 4core rad, shroud, and flex fan, (which I've never replaced) and it will barely pass 200deg.
I appreciate all the help here. I've been getting to the 3G conversion, but almost every trip my 65amper Napa rebuild fails, so I keep getting free ones. No excuse. Sometimes bearings, sometimes no charge, but I'm on like the 4th one in 50k miles. Shame about the quality of that stuff these days.
Flex fans do not so much creat turbulence as just blocking airflow at speed as the blades flatten out with RPM increases they do not allow as much airflow through the rad.
Also install the heat core shut off this will have a big impact as you won't be dumping near engine temp coolant into the cooled coolant returning from the rad.
Old Jul 29, 2020 | 03:12 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
About the water pump, I've owned the truck for 20 years, and about 60k miles. I've never replaced it, but it don't leak, flows well (visually in radiator) and seems happy. I've been hesitant to touch it, see the comment above about the alternator. Its hard to beat a known good part. If I DID have to replace it, any one use a high flow on these?
And is other than fuel mileage, what is the benefit of a flex fan over the fixed OE? I dislike the noise of the OE at road speed, but I got a bitchin radio and 2 backseat teenagers, so that might be less of a problem than its worth to fix.
Back in the 80's I worked at a shop that had a similar issue. Delivery van, checked everything , just like you have, had good flow at idle but would overheat out on the deliveries. We finally pulled the water pump off because we had exhausted all other options. The water pump fins had rusted off and was just a flat plate with little nubs left for the fins. Only one I have ever seen that way in my forty + years as a technician. Just a thought.
Old Jul 29, 2020 | 04:04 PM
ford390gashog's Avatar
ford390gashog
The spacing is critical, too close and you create a dead zone on most of the radiator. You want the fan blades just exiting the rear of the shroud. This will create the most even airflow and pull over the entire core.
Old Jul 30, 2020 | 05:31 AM
1962galaxie's Avatar
1962galaxie
Man, this is a great thread, for me at least. Clever, I'm not worried about volume of air flow, just the turbulence. I'm putting the stock fan back on asap, per the reply above about the flex fan. I used to have a bike rack on the front of this, which I moved to the rear. You could see right through it, but it was totally undriveable with heat, so it must have created dead air. On that trip, we were in Nova Scotia, and I had the stock fan still, and it stayed cool most of the trip (closer to 200deg), and now with the flex fan its hot again. I attributed it to driving in mountains vs ocean flatlands, but who knows. Perhaps I missed that clue. I will probably buy a pan and gauge soon for the trans, but that makes good sense too, because I'm sure the trans is warm at speed under load with that much frontal area. Fluid is clean and smells good, but can't hurt to know.
I'm not putting the puller back on for road speed airflow, but it will also run warm sitting in traffic with the ac on. Turn off the ac, never gets over 200. Put it in neutral and hold it 2000rpm helps a little. Plus the A/C sucks sitting still.
Old Aug 30, 2020 | 10:48 AM
1962galaxie
overheating supercab revisited
Guys,
Wanted to post some updates on this if it helps anyone in the future. I took the flex fan off my truck, and put the stock fixed 5 blade back on (because I had it easy available), and it flat out took 20deg out of it at highway speeds. Just drove it to NC with my camper, and you could run 75mph with temps never touching 200deg on a 90deg day. I then put in the RS thermostat, which did seem to make it happier in stop and go. I am still getting some higher temps sitting still with the AC on, but I put my puller fan back in, and it will idle for a long time under 210 now, so I'm pretty happy. I still need a new shroud, as mine is all taped/ zip tied together. For what its worth, the flex fan makes sense, but I've never had this experience before. Thanks for all the feedback. If anyone has a shroud, lmk. I need the narrower one, number on the shroud is D3TA-8146-BA.
NorthlandBass
Aug 9, 2016 02:13 PM
RA31925
29
Oct 10, 2013 06:12 PM
fishman35
1997 - 2003 F150
Sep 13, 2011 11:29 PM
chaoscreature
Jul 4, 2006 12:06 PM
MAHinton
Apr 30, 2002 05:26 PM
