Sponsored by: Auxito
overheating
Old Sep 11, 2011 | 07:29 PM
fishman35's Avatar
fishman35
overheating
have 1997 ford with 4.6 winsor motor ... its a f150 4wd ... i have replaced the water pump and thermostat and it still overheats ... unless i turn on the heater in the cab ? ... any idea's on what can be causing this continual overheating ? there is no water in oil so pretty sure its not head problems !
Old Sep 11, 2011 | 08:33 PM
enriched&beyound's Avatar
enriched&beyound
well the head gasket can work both ways...make sure there is NO oil in the coolant too. best way to make sure that the head gasket isn't affected is to pressure test the coolant system and test the coolant for exhaust gases
did you flush the radiator when doing the water pump?...might not hurt to flush the heater core too. How about the hoses, were they replaced?...they could be collapsing restricting flow.
Old Sep 11, 2011 | 08:46 PM
paker's Avatar
paker
A few things that you can check.
Does it lose coolant? Does cooling system hold 15 psi?
Is air flow over radiator restricted?
Is the clutch fan slipping?
Old Sep 12, 2011 | 05:00 PM
fishman35's Avatar
fishman35
has no clutch fan ... doesnt lose coolant... air flow is average thrue radiator !... this truck has duel aftermarket electric fans .... and it only overheats driving down the road its fine at an idle !
Old Sep 13, 2011 | 11:29 PM
Podaso's Avatar
Podaso
Sounds like the lower hose is collapsing, as mentioned above
mdlf350
1983 - 2012 Ranger & B-Series
Mar 17, 2014 05:47 AM
5x5F150
General Automotive Discussion
Jul 20, 2005 12:09 AM
Wangman
Oct 16, 2004 04:26 AM
mpmccarthy
Aug 12, 2004 06:32 AM
