OBD1
Old Jul 27, 2020 | 05:36 PM
Moore31's Avatar
Moore31
OBD1
1985 F150 302 with a 2 barrel feedback carb EEC-IV
Okay so another thread help me figure out a wire that was cut was a ground wire for the computer so now I am able to get my code reader to work.. So the codes I got where
22 MAP or BARO sensor out of range
31 EGR valve control sensor fault
63 Throttle position circuit fault, below minimum voltage
I don’t understand the TP code tho.. I just replaced the TPS... I’m assuming that’s the same thing...
I don’t know where to start to check anything I know nothing about checking ohms volts or whatever it is haha.. Should I replace the MAP and EGR sensor?
any help Id really appreciate!
Old Jul 27, 2020 | 07:36 PM
Moore31's Avatar
Moore31
I used electrical cleaner and cleaned the MAP sensor it had something blue on the connectors and tried the code reader again and now I only have the other two codes the MAP code isn’t showing up. So for now I don’t have to worry with it
SJP
Mar 18, 2016 08:24 PM
92F150Flare
Aug 8, 2007 05:03 PM
fordman16b
Mar 11, 2007 02:34 PM
LeadSpoon
Feb 3, 2005 03:34 PM
FreakinOldGuy
May 23, 2003 09:48 PM
