Idle very high
Old Jul 27, 2020 | 05:13 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by xenophone
Yes, that is the alternator. The black taped up cable is the negative battery cable, and the battery is just out of view. The two wires are spliced in right before the battery terminal. I'll see if I can find any vacuum leaks.
There is a vacuum tree down low and to the rear of the intake manifold. There is 1 port that has a cap that is hard to see and this cap likes to crack causing a leak.
The electric choke assist on the carb is actually not hooked up, hasn't been since I bought the truck.
This could also be the high idle as the choke is not opening and the fast idle is still on.
Dave ----
Old Jul 27, 2020 | 06:18 PM
xenophone's Avatar
xenophone
Dave ----
But, the idle issue just started a couple days ago. There may well be multiple issues here, but up until two days ago the idle would settle down as the truck warmed up.
Old Jul 27, 2020 | 07:23 PM
Franklin2's Avatar
Franklin2
If you look at the carb, your idle is controlled by a little dc motor which is operated by the computer. This is one of the nice features of this system....when it works.
Old Aug 3, 2020 | 05:47 PM
xenophone's Avatar
xenophone
I attached the old wire(s) to the negative battery post, and the idle is now functioning as it was before. The idle behavior still seems a bit weird (it always did), so I'll go through and check for vacuum leaks, and look into switching to the ECMless carb.
Thanks guys
Cruiseomatic
Jun 16, 2006 11:44 PM
OBBATEFT
Electrical Systems/Wiring
Oct 29, 2005 08:37 PM
Hammerhead
Aerostar
Jan 12, 2004 10:29 AM
Hammerhead
Jan 11, 2004 05:46 PM
spshultz
May 13, 2002 11:27 AM
