Installing EGT Probe
Old Oct 27, 2003 | 12:55 AM
  #31
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yep, you can put a relief valve in the MAP (manifold absoulute pressure) sensor line. You can put a mini regulator (like from air tools) in the same line, or you can add a 4.7 volt zener diode to the MAP sensor plug.
All three work pretty well, the regulator works the best (yes, I have tried them all). The point of all three is to not allow the PCM to see the 24 or so psi it takes to set the light.
Old Oct 27, 2003 | 06:59 AM
  #32
HeatStroked's Avatar
HeatStroked
Hey Cookie,
My boost approaches the 24 lb. and I don't want the check engine or service engine soon warnings.
You mention a zener diode in the map sensor plug. Can you give me the details on the connection? I understand the concept of the diode preventing the 5 volts from triggering sensor. Just need to know the appropriate pin connection, wire colors, etc.
Thanks!
Old Oct 27, 2003 | 09:46 AM
  #33
cookie88's Avatar
cookie88
FTE Emeritus
Sure.
Attach the banded end of the diode to the middle wire of the map sensor plug (it's green w/black trace), then attach the other end of the diode to ground. There is a bolt on the firewall just below the cowl that works great. Only need about 12" of wire.
Old Oct 27, 2003 | 09:53 AM
  #34
HeatStroked
Thanks Cookie!
Do you just use a wire tap? or can you make the tap at the sensor harness connector?
(sorry, haven't looked under the hood yet)
Old Oct 28, 2003 | 11:23 AM
  #35
cookie88's Avatar
cookie88
FTE Emeritus
Wire tap should work fine. When I was running the diode I just stripped the cover and soldered it on.
Pest007
Dec 8, 2016 11:02 PM
HowieE
Dec 4, 2016 11:35 AM
Jesser02EX
Aug 28, 2014 04:03 PM
Mattb60
Jul 15, 2013 08:04 PM
why165
6.4L Power Stroke Diesel
Mar 2, 2012 07:59 AM
