Losing power on acceleration.
Old Jul 24, 2020 | 11:30 AM
25r624's Avatar
25r624
1965 F100 FE352 Manual Tran, Manual Choke
I recently had a couple situations where my engine died; once upon acceleration up hill, once upon starting from a slight downhill stoplight.
Later, after smelling gas in the garage, I noticed a large amount of gas pooled on the manifold from a severely leaking carburetor. So I got a Wagner kit for a C5TF-Y and rebuilt the carb (Autoline C816). I set the fuel mix screws at 1.5 turns out from closed.
The truck started right up and idled fantastic (as usual), but while driving it I noticed severe lack of power upon any uphill load (ps. I live up a hill). I figured that it could be that it is running too lean rather than too rich as there was no significant smell of gasoline. I backed the screws out another half turn, but although it might be a little better it is still having the same problem.
Is this a fuel mixture problem, a blown power valve, gasket leak, or something entirely different?
I'd appreciate any help you might have.
Old Jul 24, 2020 | 01:03 PM
lewiscrouse's Avatar
lewiscrouse
Have you checked the timing recently?
Old Jul 24, 2020 | 01:17 PM
Tedster9's Avatar
Tedster9
1.5 out on the mixture screws is just a bench setting so the engine will start, and idle, so they can be fine tuned after the engine is good and warmed up. Turn the screws in from that point to lean it out for a proper idle mixture setting. Even 1.5 turns out will likely be way too rich and will tend to foul plugs badly.
I'd back up your tuning a bit though, first make sure the fuel pump output pressure is within spec.
Everything in the carb, every setting and adjustment, is based on neither too little nor too much fuel being delivered. A mechanic's vacuum gauge will measure fuel pump pressure quickly and easily. It is also a great aid to engine diagnostics, and carb adjustment. About 5 psi is plenty. Then re-set the float height as required to achieve the proper fuel height in the carb bowl. Aka "wet height". This is another important adjustment that affects everything else downstream.
Old Jul 24, 2020 | 08:04 PM
daveengelson's Avatar
daveengelson
Agree w/ both members comments. Similar situation with my 65 with 1964 352/390. I set what I thought was the correct timing then took the truck for a trial run and barely made it up my steep driveway, I reset the timing at around 10-12 degrees and much improved. I had installed the Dura-Spark ll ignition set-up many years ago however the timing, whether point or electronic ignition, would the same; plug gap would be different.
Old Jul 24, 2020 | 08:19 PM
Christmas's Avatar
Christmas
What carb do you have?
Ignore this post; Autolite
Old Jul 25, 2020 | 02:41 AM
farmalmta's Avatar
farmalmta
The engine is likely fuel starved.
1) ensure the carb float is set correctly.
2) ensure no blockage from the fuel pump to the carburetor. Remove it and run a wire through it, then blow air through it, then soak in solvent for 24 hours, then more air. Or replace it
3) check fuel pressure and otherwise make sure the fuel pump is operating correctly without weak diaphragms, which can at first give intermittent problems
4) make sure the fuel line between the fuel pump to the gas tank is not blocked using same procedure as 2) above.
5) make sure the fuel pickup tube is clear and that no debris is on the bottom of the tank. Seal coatings like POR come loose and cause lots of problems. Clean and boil tank or replace.
Hope this helps.
Old Jul 25, 2020 | 07:54 AM
Crop Duster's Avatar
Crop Duster
Have you replaced the canister fuel filter on the fuel pump lately? I ask because a lot of people don't realize there is a filter in there and end up putting a second filter between the pump and carb.
Old Jul 25, 2020 | 11:57 AM
25r624's Avatar
25r624
So rebuilding the carb will affect the timing?
Old Jul 26, 2020 | 11:35 AM
Tedster9's Avatar
Tedster9
No, but the correct timing - initial ignition timing especially, will directly affect the manifold vacuum the engine will pull.
More ignition advance = more engine vacuum, generally speaking. Up to a point. Virtually every factory stock engine ever made pulls 19" to 21" at sea level. If it won't, find out why, the engine will not run right and can't be made to run right. This is one reason why the old saw "90 per cent of carb problems are ignition related." Vacuum leaks also cause lots of problems.
An engine actually moves hardly any air through it at idle or just off idle (where much driving is done) so a separate carb idle circuit is employed that utilizes engine manifold vacuum to achieve the high velocity necessary to finely atomise the air/fuel mixture.
While it's called the "idle circuit", its adjustment is critical to bog-free acceleration and also contributes a fair amount of juice up to around 35 mph or so, when the cruise jets take over.
Old Jul 27, 2020 | 01:26 PM
25r624's Avatar
25r624
Ok. Quite a list of possible things wrong here. Sounds like I should probably change the fuel filters and start looking for a vacuum leak first. If no leak, I'll move to timing, then possibly some other things y'all suggested. It's not my main means of transportation so might be a while before I get to it but I'll update y'all once get to it.
Thanks guys!
Old Jul 27, 2020 | 05:00 PM
25r624's Avatar
25r624
Problem solved with timing! No vacuum leaks that I could find.. advanced the timing and it Runs great now even up the big hill! Running strong at all acceleration points! Thanks guys!
Mike
Old Jul 27, 2020 | 09:55 PM
lewiscrouse
On my most recent road trip I ended up having to redo the timing halfway through and that caused the motor to do all sorts of funny things, but that just makes you appreciate a well running engine all the more.
michea
Oct 9, 2012 11:04 AM
mward69
Sep 21, 2008 02:41 PM
Scott Fraser
Nov 24, 2004 10:25 PM
87carbed
Oct 22, 2004 06:51 PM
proeliator
Jan 19, 2001 10:54 PM
