need help with yoke flange
Old Jul 24, 2020 | 09:39 AM
BayStYat's Avatar
BayStYat
I did an 2001 Explorer 8.8 swap. I have the large bolt pattern pinion flange on the 8.8. I need help with part number for the correct yoke flange on my F100 drive shaft.
thanks everyone
Old Jul 24, 2020 | 11:00 AM
Lrrr-RulerOfOmicronP's Avatar
There are conversion u-joints that have two different sizes. I used one to adapt a 1410 to 1350. I will update all to 1410 at some point down the road. As for finding a driveshaft flange I am no help.
Old Jul 24, 2020 | 12:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's another that is 1310/1330. Two cups are 1310's, two cups are 1330's: C5TZ-4635-F .. Spicer # 210392-X
Old Jul 24, 2020 | 02:00 PM
RichS2659's Avatar
RichS2659
Visit your local driveshaft shop to get the proper conversion parts needed.
Old Jul 24, 2020 | 06:15 PM
BayStYat's Avatar
BayStYat
thank you gents!
Old Jul 24, 2020 | 06:41 PM
cbrown9064's Avatar
cbrown9064
And beware there is 1330 and 1330F. The 1330F is a 1-1/8" cap size, and the 1330 and 1310 are 1-1/16" cap size. And there is a "special" u-joint that is a 1310 one dimension and a 1330 the other dimension. AND...there is even a super special 1310/1330F u-joint. Ask me how I know all this...
IIRC, the 1350 is an even bigger cap size, but dont quote me on that.
So, what are you looking to do? Get a yoke for the 8.8 or get a flange for the driveshaft?
Old Jul 26, 2020 | 07:25 AM
BayStYat's Avatar
BayStYat
thank you, I am looking for the flange for the driveshaft.
Old Jul 26, 2020 | 10:14 AM
cbrown9064's Avatar
cbrown9064
https://www.dennysdriveshaft.com/c59_ford_8.8.html
Should find what you need there, looks like they have small and large. Then see what ujoint is stock on your truck. If the driveshaft side is 1310, then you are golden with a new 1310 joint.
Old Jul 28, 2020 | 09:17 PM
BayStYat's Avatar
BayStYat
thank you sir
jefhuf
WTB - Parts & other
Mar 27, 2013 10:15 AM
ErrorS
Nov 22, 2010 12:27 PM
needs more mudd
Apr 7, 2008 01:48 PM
my468
Aug 20, 2007 04:16 PM
