Sponsored by: Kumho
Alignment issue
Old Jul 21, 2020 | 10:25 AM
Stefan Leblanc's Avatar
Stefan Leblanc
Alignment issue
I have a 26 ft RV sitting on a 2014 E450 cutaway. On periodic inspection my mecanic told me I had to replace the drag link and tie-rods but he didn.t have time to do so and anyway he doesn't do alignment.
So I went in an alignment shop that do trucks, there not many nearby so they are very busy. I have them change the drag link and they told my that only 1 tie rod needed to be changed. They do the work and the alignment. They also centered the steering wheel. it looks nice and strait: 9-3. I come back home about 35 kms (15 miles) from there and the steering had shift a little bit to the right, it' was tgen at 10-4. I had a quick trip Montreal-Toronto planned so I made about 1000 Kms (600 miles) the next weekend. When I came back the strearing wheel had turn 90 degrees (12-6) and by the time I maid it to the alignment shop it was even whorst (1-7) All that time the truck was not pulling and was going pretty straight when I was removing my hands of the steering...
They looked at it and told the the direction was all stiff,. nothing loose, it was all the same as when I left, except that the steering wheel wasn't at the right place... The never saw that before and had no clue why it did that. So they re-did the whole allignment, re adjusted the steering wheel. The technicien told ne he re-thigten all bolts even added a little tention over what it should be... We'll see if that holds..
I have heard many poeple saying their steering beeing crocked after alignment, but never heard about the position getting worst!!
Anyone have an idea of what could have happen ?
Old Jul 22, 2020 | 04:52 AM
JWA's Avatar
JWA
Check tire pressures and tire wear with a tread depth gauge across the width of each front tire.
Could possibly be the roads you've been traveling---some are constructed with varying degrees of crowning which do affect how the vehicle's steering wheel will "center" itself.
Old Jul 23, 2020 | 12:06 PM
mark a.'s Avatar
mark a.
Not saying this is whats wrong with it, but that's just how a steering boxes pitman shaft acts before it sheers off.
Old Jul 24, 2020 | 04:48 AM
JWA's Avatar
JWA
That's some scary shyte huh?
So hoping that's not OP's case though---I thought a blown lower seal on my steering box was major.
Old Jul 24, 2020 | 08:26 AM
Stefan Leblanc
Would a alignment/steering specialist awared of the issue be able to not see something that major ??? I went back to the alignment center and they told me everything was fine ... That suck
Old Jul 24, 2020 | 08:53 AM
Stefan Leblanc
Would a steering / alignment specialist be able to not see a so major issue ? They said everything is okay when I came back... I will still drive it a few hundred miles to see if the issue is reproducing...
crgray1095
Nov 6, 2019 08:01 PM
Armyrules2
Dec 11, 2017 09:51 PM
JethroF250
Feb 28, 2008 04:34 PM
1984 f-250
Nov 26, 2005 08:39 PM
WVF150VIANC
3.8 & 4.2L V6
Mar 8, 2005 10:22 AM
