Front end Binding
Old Jul 21, 2020 | 03:29 AM
StarFox's Avatar
StarFox
Front end Binding
Bought my '08 4x4 Screw used, it came with a 2" lift.
I have never had 4x4 previously but doubt that the truck should bind up in 4x4 during a tight turn in the parking lot. The truck will cease to move as I tighten the turn. I'm wondering if the truck was lifted improperly. ( I believe they used a 2" puck)
I am replacing the struts and am wondering if I should be replacing other parts at the same time to remedy the problem.
I'd have to check on my tire size, but I think they are stock.
Thoughts?
Old Jul 21, 2020 | 05:04 AM
seville009's Avatar
seville009
A truck will definitely bind up while turning on a dry parking lot with 4wd engaged.
You do not want to be doing that
My advice would be to download and read the manual.
Old Jul 21, 2020 | 07:34 PM
StarFox's Avatar
StarFox
Sounds like something I should be doing....I didn't think of that.
Thanks!
Old Jul 22, 2020 | 05:37 AM
seville009's Avatar
seville009
It’s nice having the manual on my phone because it’s easily accessible when I need it, and it’s a searchable pdf file, so it’s quick to find what you’re looking for.
I have the manuals (user, parts, repair) for all my vehicles and equipment on my phone.
Old Jul 22, 2020 | 11:37 AM
Lime1GT's Avatar
Lime1GT
Nice way to break the transfer case and other parts.
Old Jul 23, 2020 | 08:55 AM
WWR's Avatar
WWR
It isn't great for the drivetrain to do this but it's unlikely to break anything, and if it does those components were likely close to failure anyway.
But yes, binding is normal and an "improper lift" wouldn't affect it one way or the other.
Come out to Moab and spend some time locked front and rear on slickrock and you'll see binding.....
Old Jul 24, 2020 | 08:33 PM
Lime1GT's Avatar
Lime1GT
[QUOTE=WWR;19395859
Come out to Moab and spend some time locked front and rear on slickrock and you'll see binding.....[/QUOTE]
Lol, I live on the prairies with frozen winter flat land. For the most part the closest thing to an incline here is going up the ramp of a underground parking lot.
Old Jul 31, 2020 | 05:03 PM
1saxman's Avatar
1saxman
You never get rid of that 'binding' feel when turning a tight radius in 4WD even on loose/slippery material, but like said, you should never engage it on non-slippery material. The torque caused by one end fighting the other when the axles are locked, particularly when turning, can be a huge factor and definitely break things, like the transfer case. On loose/slippery material, the wheels can slip to relieve the torque, so that's why you never use it on dry pavement.
Stinger10
May 20, 2011 04:48 PM
Dutter
1983 - 2012 Ranger & B-Series
Nov 10, 2010 11:31 PM
Hardcorecanuck
Jun 15, 2010 10:31 PM
supraguy07
Offroad & 4x4
Dec 5, 2005 09:55 PM
64ford4x4
Apr 5, 2004 11:25 AM
