Step to no step bumper
Old Jul 17, 2020 | 10:18 PM
Butl85's Avatar
Butl85
I know the stock brackets are harder to find than diamonds but I just wanted to see if anyone fabricated the brackets and if there is a method for this that is best? I am pretty good with metal as I work with sheetmetal on airplanes but it is thinner stuff. I'm assuming .250" would be the minimum thickness for brackets if I were to make them? I cannot believe LMC does not sell these.
Old Jul 18, 2020 | 07:26 AM
FuzzFace2's Avatar
FuzzFace2
When you say stock brackets what is meant by that as our trucks did not come from the factory with rear bumpers.
If the state said you needed one or the owner wanted one the dealer installed it.
Now where they got the brackets from who knows?
Maybe from the company they got the bumpers from?
What rear bumper are you wanting to install, Bronco bumper?
Maybe look into using Bronco brackets even as a start and mod as needed to work think would be better that building from scratch.
Should back up a little is this for a Style Side or Flare Side?
A member makes the brackets for the Flare Side bumper. I don't know if they will work for a Bronco bumper or not?
Again you would not be starting from scratch.
Dave ----
Old Jul 22, 2020 | 01:48 PM
1986F150six's Avatar
1986F150six
Send a PM to reamer, a fellow forum member. I believe he has manufactured what you are seeking.
Old Jul 22, 2020 | 04:49 PM
FuzzFace2's Avatar
FuzzFace2
He made the bent brackets less the holes IIRC and they are for the flare side bumper.
Now because the holes are not drilled could they be used to mount a different bumper?
I don't know but someone has to be the first.
Dave ----
Old Jul 23, 2020 | 07:38 AM
ozark1's Avatar
ozark1
I did this on my '84 a few years ago. We made the brackets that we welded to the step bumper brackets...Then..you will have to cut a notch in the bumper to fit it up to the body.. Use a plasma cutter..then hand file the cut edges. Then weld or bolt the new bumper to the brackets..Search..ozark1...for a photo of mine..
Az58Cameo
22
Feb 4, 2016 01:43 AM
Moe Craig
Nov 17, 2013 10:44 PM
Pastortom1
Mar 28, 2013 01:28 PM
garthneddy
Nov 29, 2012 01:38 PM
Spud7
1978 - 1996 Big Bronco
Feb 12, 2002 03:18 PM
