1974 F250 with factory air conditioning. I need to buy a heater valve for the heater hose. The actuator has 2 air fittings, so far the only ones I can find are for the later style with one fitting. Is it possible to use the single fitting style by connecting it to the correct hose and plugging the extra?
I am unfamiliar with the valve you have. It would help if you could post a photo of it.
Valve assy., heater water control
Fits: 73-74 F100-350 w/ integral A/C before s/n U40,001
D0DZ-18495-A
Dennis Carpenter, Concord, NC shows 5 in stock (704) 786-8139
Thanks for the diagram, it looks like they modulate the water flow to control the temperature. It must have been less than optimum because the change to single port valve later. I think I have a 1975 HVAC control panel. i will locate it and see if it will swap out.
There's only ONE heater water valve for 1974's from serial number U40,001 & 1975/79 // see all the applications for this puppy
It's spliced into the heater hose on the right rear of the engine compartment.
D4AZ-18495-A (replaced D1AZ-18495-A) .. Vacuum Controlled Heater Water Valve - Use with factory installed integral A/C (Motorcraft YG-136) / AVAILABLE from Ford & auto parts stores.
Why can’t anyone just give an answer to peoples questions on here!?!? CAN YOU USE AN AFTERMARKET VALVE W ONLY 1 VACUUM LINE IN OR NOT? And HOW DO YOU HOOK IT UP?ALSO WHY DO THEY NOT MAKE PARTS ANYMORE THAT JUST INSTALL SAME AS BEFORE?!?!
