Carburetor
Old Jul 14, 2020 | 07:45 PM
Kingcw1966's Avatar
Kingcw1966
Carburetor
Trying to figure out what would be the best carburetor to use on a 351 Modified
Old Jul 14, 2020 | 08:29 PM
440 sixpack's Avatar
440 sixpack
2V or 4V ?
Old Jul 15, 2020 | 05:20 AM
Kingcw1966's Avatar
Kingcw1966
Originally Posted by 440 sixpack
2V or 4V ?
its got 4 valves per cylinder, at the moment we have a holly on it but it will not prime up enough fuel to crank on it's own, we wanted to ask on this site and find out what might be wrong with this carb and what's the best carb to use on this engine
Old Jul 15, 2020 | 06:54 AM
CelticOne's Avatar
CelticOne
Regular User
The "V" in (2V or 4V) is for Venturi. In other words, Do you have a 2-barrel or 4-barrel carburetor/intake manifold?
Old Jul 15, 2020 | 07:02 AM
Kingcw1966's Avatar
Kingcw1966
it has a 4 barrel carb a 650 Holly
Old Jul 15, 2020 | 08:37 AM
CelticOne's Avatar
CelticOne
Regular User
Here are some related threads that might be helpful:
https://www.ford-trucks.com/forums/4...carb-size.html
https://www.ford-trucks.com/forums/5...-for-351m.html
https://www.ford-trucks.com/forums/1...-for-351m.html
https://www.ford-trucks.com/forums/1...placement.html
There are more. I Googled: "351m carb size site:ford-trucks.com"
Old Jul 15, 2020 | 08:42 AM
caravaggio2000's Avatar
caravaggio2000
If fuel is not getting to the carb, that's not a carb issue. Your fuel fuel line might be clogged with rust, have pin holes, or something. Are you still running a mechanical pump?
Old Jul 15, 2020 | 10:14 AM
barnyard's Avatar
barnyard
600cfm holley w/ electric choke. the factory motorcraft 2bbl is fine with a stock engine though.
Old Jul 15, 2020 | 11:23 AM
440 sixpack
What Barnyard said.
351Cleveland C4
43
Nov 28, 2014 10:09 AM
FORDbigblock4X4
Offroad & 4x4
Jun 28, 2004 10:05 AM
F-250Custom
Sep 11, 2003 10:39 AM
FordRacing2
15
Aug 12, 2003 09:39 PM
