428 first fire up
You should have no vaccum on the ported vacuum for the dist at idle. If you do idle settings and or secondary throttle plates need to be adjusted. That is the whole point of the ported vac or the dist.
Remove the vac line from the Dist when adjusting the idle mix or any other idle settings.
They are to be done one at a time. Again make sure the dist vac is disconnected and the line capped. And be sure the engine is warm (at or near operating temp).
Start at one of the primaries and adjust it till max manifold vacuum is achieved then on to the next primary then do the secondaries. If the base idle speed changes (increases) after setting the idle mix adust it back down and then re-verify that the idle mix is correct and still set for maximum manifold vac in the same pattern as the initial adjustment.
Once done go back to the first primary you adjusted and verify it is still set to achieve maximum vacuum if not readjust and follow up with the others. And adjust idle as needed after each adjustment round.
You may have to do it few times get it set.
Then verify that you have little or no vacuum on the ported vacuum for the dist. If you do base idle setting is too high and the primary throttle plates are uncovering the ported vacuum port in the venturi.
So as you can see it can take a bit of time and is sort of like chasing your tail. But eventually, you will get it dialled in.
If you have any issues with still getting high vacuum on the dist ported after doing this let know and we will resolve that.
Nice lookin' truck.
May I suggest the following, as I think your focus is too broad at the moment.
1. Connect the pcv stuff and swap the dizzy vacuum advance from ported to full manifold, as already discussed.
This will in effect advance your timing quite a bit, and should allow a smoother idle.
2. Turn the carb idle speed screw whichever way is needed to get to 800rpms.
3. Assuming it will idle now, read the vacuum gauge. Post up the needle behaviour and vacuum level, or google how to read vacuum gauge readings.
4. This will tell you what needs to be addressed next.
5. Thereafter, you can dial in the idle timing, timing curve, vacuum advance, and carb.
The 1 1/4 carb screw settings will be fine as a starting point.
This was the what oil fill cap I had on originally
Plugged rear port in intake manifold. Will open it back up for tranny modulator
This was that original intake T deal. I’m doing away with it and running 1 hose direct to carb for pcv. Unless I must have this?
Plugged front intake manifold port. Going to keep it closed up for good
Pcv valve. Which I’ll run hose from here to front big port on carb
Plugged port for distributor. All ports on carb are plugged off as of now. Will fire her again this evening with more results
The PCV pipe should not be T'd, so having its own dedicated pipe is also perfect.
The ported vacuum port on the carb, shown in the pic with the yellow cap, is above the lower full manifold vacuum port, and both ports are the same size.
Connect the dizzy to that lower smaller port, full manifold vacuum, for this evening.
I hope that makes sense.
It would look neater in the future if you use the rear intake manifold port for the PCV pipe. Just saying.
It's ok to run a brake booster, transmission modulator or whatever other device needs vacuum. But not a full-flowing PCV system.
Paul
At idle at 800
2500 rpm
seems to be idling fine with all ports closed off and gauge on bottom port of carb
At idle
This is the lowest rpm I can get with idle screw. So I may need to change timing?
This is at an idle after adjusting idle mixture screws. 900-950 rpm
Here’s 2500 rpm
Looks like you might have a rather a lumpy cam in it.
The Curb idle on most 428's from the factory was between 675 and 725 even the CJ drag pack fell in this range. They were at 6° base timing. So you could try backing down the base to say 8° or so.
Your cam may need manifold vac instead of ported also. Hard to tell without a cam card.
