428 first fire up
Old Jul 13, 2020 | 11:50 PM
dwirth's Avatar
dwirth
Ok I follow now. The engine did seem to do better after running it on premium vs reg unleaded. Unless I’m imagining things
Old Jul 14, 2020 | 08:15 AM
somethingclever's Avatar
somethingclever
disconnect the vacuum advance hose and put a cap on the carb side port
eliminate this system to start
set initial timing (at idle rpm) to 12-15 deg BTDC.
double check the timing marks adn pointer is correct wtih a piston stop if you have any doubt
start truck...if it doesn't idle relatively smooth and hold a vacuum showing 1-2" of bounce (with a decent gauge) then next step is to look further for vacuum leaks.
I suggest to disconnect all vacuum sources and confirm teh engine proper is good...then reconnect 1 vacuum line at a time.
If the carb is new i doubt it's your issue.
Old Jul 14, 2020 | 08:22 AM
dwirth's Avatar
dwirth
I’m positive my timing marks are right. I set #1 cylinder at TDC and the timing marks all jived good. I’ll start with vacuum lines to eliminate issues
1 line goes to booster
1 to dizzy
1 to pcv
1 to dash
tranny vac not hooked up yet
can I cap them all without side effects for checking process
Old Jul 14, 2020 | 09:23 AM
440 sixpack's Avatar
440 sixpack
Your initial timing setting means absolutely nothing unless your distributor curve is spot on. assuming it's fine is a big assumption since they seldom are. find your peak mechanical advance setting and if your distributor is even close the initial will take care of itself. .
Old Jul 14, 2020 | 09:32 AM
Dustin Daniel's Avatar
Dustin Daniel
Yes you can plug all of them. Likely a good idea. I would not suspect a new carb just yet unless the settings are way off, could be. Do what the prior poster up from you stated. Then report back.
Timing is base, plus advance. Advance comes from RPM(weights and spring rate) and vacuum adds to this. One reason you pull vacuum advance out of the equation to start. Base timing at idle should be as stated 10-15 btdc, you can do more if the motor wants it but you are not to that point yet. Know that a change here impacts TOTAL timing by the same amount. BASE+ MECH. ADVANCE=TOTAL. Total timing, no vacuum, is what you need to watch out for. Depending on the setup it could be 35(modern heads) or if all factory more like 42 total(Iron heads). More to it than just this but the info is out there on the web on how to find it. Learn it because it is an important thing on older motors like this.
Good luck.
Old Jul 14, 2020 | 09:56 AM
dwirth's Avatar
dwirth
Here is a pic of plug off #5
and a few others of the build
Old Jul 14, 2020 | 12:53 PM
matthewq4b's Avatar
matthewq4b
Have you adjusted the idle air mix? That will affect idle more than anything if the timing is at least ballparked.
Old Jul 14, 2020 | 01:08 PM
dwirth's Avatar
dwirth
yes but not 100% it’s correct. Screwed all 4 corners in then backed out 1 1/4 turns. Ended up putting them all in 1/8 of a turn from 1 1/4. The 2 back ones were almost screwed all the way in when I started
Old Jul 14, 2020 | 01:13 PM
Sliding-Down-a-Dream's Avatar
Is your PCV system connected ?
The oil filler cap on the driver side valve cover looks solid, and should have a built in filter, or, a pipe connected the the air filter casing.
If you're at sea level, your vacuum reading should be +/- 18'' connected to ported, or +/- 20'' if connected to full manifold, both with vacuum advance plugged.
Also, that reading will be at +/- 800rpm, not any higher.
Old Jul 14, 2020 | 01:15 PM
Initially, to help with idle, connect the vacuum advance to full manifold on the carb, and plug the ported.
With a better idle, you can then get a better vacuum reading.
Old Jul 14, 2020 | 01:17 PM
dwirth's Avatar
dwirth
I have some stuff disconnected in those pics because I’m working on disconnecting vacuum lines off. I switched to that silver cap and have not run engine with that cap. The first one has an elbow on top for going to air cleaner. I didn’t know if it would make a difference between the caps
Old Jul 14, 2020 | 01:19 PM
dwirth's Avatar
dwirth
I will try this as well. Hope to fire it up this evening again
Old Jul 14, 2020 | 01:22 PM
  #28
As long as you have a fresh air intake on one side, and the correct pcv valve connected to intake vacuum (back of carb maybe) on the other, your pcv system can be ignored for now.
Swap to manifold vacuum for now, and if nothing else, you'll have observed the difference it makes.
Old Jul 14, 2020 | 01:24 PM
  #29
Ok, good. It will make you smile and make life a little easier.
Old Jul 14, 2020 | 01:33 PM
  #30
matthewq4b's Avatar
matthewq4b
You need to hook vacuum gauge to manifold vac and adjust them for max intake vacuum. Not sure if that is what you did. Turns in out is just the default setting to get it to run.
You should have no vaccum on the ported vacuum for the dist at idle. If you do idle settings and or secondary throttle plates need to be adjusted. That is the whole point of the ported vac or the dist.
Remove the vac line from the Dist when adjusting the idle mix or any other idle settings.
