Fan Clutches
I have used a stock fan clutch, the snow plow clutch and the BPD adapter with a 7.3 fan clutch.
It seems like the plow fan clutch cools things down quicker but the truck still gets warm before the fan kicks in and this would be in the PCM programming.
The 7.3 fan clutch seems to make the A/C work better at idle on both max and regular. The 7.3 clutch seems to be engaged more often though. I should source another one and see if it matches the one I have now.
Has anybody talked to the tuners to see if they can be more aggressive with fan clutch engagement in the custom tunes?
This is from another thread:
After I replaced the cooler with a thorough flush, I never saw anything over 210 on the oil temp at 2k RPM's.
The shop I used for the stud job wasn't happy that I didn't want to replace the cooler when they had the engine out. I had him on the phone as I pulled over when the heater hose blew last year! I was asking him if I was going to owe him another $5k for a head gasket job! The temps climbed quick on that one. I saw 230 F on the water and 255F on the oil. I pulled the filter to make sure I didn't melt the stand pipe. I was sweating that I tossed my $ with that over heat..
At 70-75 I am turning 2k RPMs and I run around 224-226 oil temp and the coolant temp was between 214 and 220 depending on hills and when the fan would cycle. This was on i94 between St. Cloud and Valley City, ND so it wasn't totally flat.
I brought my 7.3 fan clutch and the fan clutch tools this weekend and swapped the fan clutch for the ride home and then the coolant temps were between 196 and 202 and oil temps were 206-210 at the highest. I wonder if the fan programming isn't as aggressive with the Gearhead 8K tow tune?
I am also thinking that the 7.3 fan clutch I have is locked up more than it really should be as I can hear it quite a bit unloaded and before the engine warms up. I am on the fence on this one.
Has anybody talked to the tuners about fan clutch tables?
I replaced the original fan clutch with a new motorcraft and saw an immediate improvement. The only time I see higher than normal temps is when stuck in backups on the interstates, as soon as I see the temps get above 210 I switch the ac to max, that kicks the fan to high and the temps come right back down.
I don't experience high temperature/fan issue yet. But if I do, I would look into controlling the fan speed more precisely than just grounding the blue wire. Basically, try doing what the engine does, just with a higher speed or custom speed of your choice. Besides I don't have problem with the fan or the temp, I am mighty busy currently though, so I don't see myself doing any of that anytime.
There are currently many options people talked about, including grounded blue wire mod, 7.3 fan mod, electric fan mod, upgraded 3rd party fan mod. Some even talked about tune mod. I think this is another solution. The truck computer will still see the fan speed, and may complain if it's faster than what it should.
I don't normally monitor fan speed but might have to add that just to see what it does and when it does it.
Also, and this is crucial when you replace a fan clutch on a 6.0L. BUY ONE FROM AUTOZONE. Motorcraft may warranty your clutch for two years if you have a receipt, but the fact of the matter is that nearly all of the 6.0L fan clutches now are re-manufactured and are supplied to aftermarket as well as OEM manufacturers as "replacement parts" and I have verified this on several occasions. Autozone has a lifetime warranty on this part and you can just bring yours in and swap it out at any location.
This being said, (and this is the crucial part) Ford's new fan clutch box does not have a "storage direction" printed on it. This is CRUCIAL if the part is expected to sit any amount of time. If the clutch is stored on it's side or upside down, the viscous fluid will seep past an internal seal and partially or fully lock the clutch and the condition is irreversible without disassembly. I have purchased three fan clutches (in a row) from Ford that had this problem, just to have them tell me that my truck had a problem. When I discovered (by purchasing an autozone branded unit) the storage procedure, I discovered that the dealership I was going to had stored these clutches sideways on a shelf to save space, as the box didn't tell them otherwise. I also confirmed this procedure with "Horton industries" a re-manufacturer of many fan clutches (and this one).
I need to get curious one day and experiment with IDS and put it @ 100% duty cycle and see if it locks up. If it don't, I'll try your Autozone clutch..... maybe.
Here's been my experience:
-Both of my 6.0's with stock electronic clutches did not do this.
-02 F150 5.4 with stock mechanical clutch would not do this.
-89 Mustang 5.0 with Hayden mechanical clutch would do this. Quite annoying. Went to a stock motorcraft clutch and it went away.
Also the more I think about it could be the on cold starts it only locks at 100% when the AC compressor is on. I'll have to run an experiment. I recall it would do it in cold weather as well which if it was related to the AC compressor would probably be in defrost on the HVAC.
Tuned was done years ago. Truck has yet to overheat. AC is COLD! I would be a little hesitant to update my old *** 3015( I think) for fear of getting some of the tuners abilities taken away.
