That actually helps a lot thank you, ill mess around with it and see if im able to cut a little out to help if not then Ill just be real careful haha if I break a front diff I guess ill just go to 2wd, I got plenty of 4x4 parts so im not too worried about messing much up
I looked at my truck and seems like axles and diff are gonna be my two main problems but the axles I can see easily and it seems like I can just cut above them and clear but I cant see above the diff easily I will just have to take out the springs and use the engine hoist like you said
Since I had such a lack of information here ill just keep updating what ill do for anyone who does this in the future but I think im gonna have good wheel fitment measured the fender to the ground and its 33.5 inches (bad suspension might be lowering this) so if I take out 20 inches for the wheel, 10 inches for the tires (5 inch walls), and ~2.5 inches for a drop then that will leave me with like a 1 inch gap in between the tire and fender which im happy with might go with 18 inch wheels too not sure yet
