Lowering a 4wd
Old Jul 12, 2020 | 04:00 AM
NickD2021's Avatar
NickD2021
Exclamation Lowering a 4wd
Hey guys looking at a 1996 F150 thats 4wd and want it to be lower sort of like a lightning, I know you can only get about 3 inches in the front before I get into problems and maybe 5 at max. I got a 4wd and thats what im gonna lower no remarks please. Im looking to get anywhere from 3-4 inches for the front but dont know where to start besides cutting the springs :/ any help is appreciated
Old Jul 13, 2020 | 07:10 PM
NickD2021's Avatar
NickD2021
bumping this :/ need the help
Old Jul 13, 2020 | 07:43 PM
Mudsport96's Avatar
Mudsport96
I'm not sure you can get a drop like that without running into issues with the front axles. They only travel so far and I would think that they are more designed to travel downward like unloading the suspension not upward in a lowering application. You may run into binding, I do not know. That may be why nobody replied, they arent sure how to lower a 4wd truck
Old Jul 13, 2020 | 08:38 PM
rla2005's Avatar
rla2005
Your project scope is analogous to pushing a rope up a hill. Everything is probably going to need custom made. Not too many folks try to slam a 4x4 OBS truck.
Overcoming the suspension geometry limitations is going to seriously thin your wallet.
Old Jul 13, 2020 | 10:45 PM
eagle275's Avatar
eagle275
Dude - make that a nice 4x4 you'll be envied. Then you can run a Prius when they get in your way. Lol!
Old Jul 13, 2020 | 11:38 PM
NickD2021's Avatar
NickD2021
im not trying to slam it or anything, like I said up there I know you can go about 3 inches before problems so thats what I'd like to do but I dont know how to go about, different type of suspension? anything helps
Old Jul 14, 2020 | 03:18 AM
Mudsport96's Avatar
Mudsport96
Read this.
https://www.f150forum.com/f88/option...189907/index2/
Apparently a 2front 4 rear is pushing it with the 4x4 parts. A 3/5 requires swapping in 2wd beams
Old Jul 14, 2020 | 07:46 AM
ZSK's Avatar
ZSK
Do you have the truck already or are you still shopping? My first step would be to pull the front coil springs and shocks, and then drop the truck on the bump stops to see what you're working with. You'll need to make sure you have clearances for the differential and driveshaft when you go lower, if it looks ok on the bump stops, pull the bump stops and check again. Figure out the up travel and then work from there to establish ride height and overall travel numbers. The TTB won't lend itself to easily going low without frame clearance, if the real goal is a low 4x4, you might be ahead to look at a 97+ F150.
Old Jul 14, 2020 | 02:49 PM
NickD2021's Avatar
NickD2021
Just got it this last weekend plus 5 other parts trucks in varying conditions so I can ruin some parts and have extras since most of them dont have titles so ill mess around
Old Jul 14, 2020 | 03:40 PM
NickD2021's Avatar
NickD2021
Found some shocks from that option forum so Ill probably go with that and get the 2 inches all the way around and then see how much room I have to work with and then maybe do springs I guess in the front until I cant go anymore thanks for the help guys
edit: heres the shocks im talking about for any future people seeing this https://www.belltech.com/products/be...ered-9231.html
also if anyone has any comments about them id like to know too
Old Jul 14, 2020 | 08:59 PM
eagle275's Avatar
eagle275
I read about the shocks and like what I read about the OEM shocks. I have a 96 F350 4X4 and I'm sorry I can't help you out on the one's you are looking at. All I can say is talk to their tech support and wish you the best!
Old Jul 15, 2020 | 01:05 AM
NickD2021's Avatar
NickD2021
Another interesting thought I had is would a normal lowering kit (usually advertised as 2wd kits) work on a 4x4? I have no idea because ive never had a 2wd.
Old Jul 15, 2020 | 11:47 AM
Mudsport96's Avatar
Mudsport96
In case I missed it, are you trying to keep the 4 wheel drive functional?
Old Jul 15, 2020 | 09:23 PM
NickD2021's Avatar
NickD2021
Trying to keep it functional but if I cant get the desired stance ill just spend the $500 for a parts truck
Old Jul 15, 2020 | 10:50 PM
Mudsport96's Avatar
Mudsport96
Well, camber issues aside, your best bet would be to get a engine hoist and chain and use that to lower to the height you want after pulling the springs. I think the front diff is going to be your problem.
Now I know my springs are worn, but my truck only has about 2.5 inches between the top of the diff and the engine cradle... maybe 3. So if you are wanting to drop 2/4 then you will have less than a half inch to work that area. Granted that's inset so wheel travel will probably be around 5 inches, but that's just a unnoticed pothole before slamming hard parts into each other.
